Get "On Star" -like system for your car, free.
With a cheap mobile phone and a DTMF (dual tone multifrequency) decoder, you can get a system to unlock your car's doors, to turn off the engine, to trigger the siren or horn, or just about anyting you can think of with remote control (from any place you can dial up to your car's phone number).
Step 1Get your stuff.
Get your stuff.
You'll need:
-A mobile phone that has a hand free port. And which you can configure to self answer any incoming call. (Motorola C133, which I used has this feature).
-A hand free for your cell phone. (got it for 1 US at Waldo's 1 dollar mart)
-A car charger/adaptor for your cell phone (Waldo's to the rescue)
-The most critical of all: a CM8870 dtmf decoder IC. In Mexico, AG electronica has them. It is considered obsolete in USA, but If you can get it in Mexico, you can certainly get it in the US.
-a 3.579545MHz quartz crystal
-2 x 100 KOhm x 1/4 W resistors
-1 X 330 KOhm x 1/4 W resistor
-3 X 100nF ceramic capacitors
-7805 voltage regulator IC
-1000 uF X 25 V Filtering capacitor
-4 x 12 V Relays (I used automobile type)
-4 x BC548 or any small power PNP transistor.
-4 x 4.7 KOhm x 1/4 W resistors
-4 x 1N4001 diodes (to dissipate back emf from the relays)
-Printed circuit board (prototype board)
-A nice plastic housing (I used a discarded wireless phone base station)
65 comments
1-40 of 65next »
Jan 2, 2012. 6:19 PMMythbuster Kid says:
Seems a little bit over complicated.
Oct 16, 2011. 4:00 AMChebog says:
Sir, question? how many source is required in the circuit? is it 2 source? Source from the 7805 voltage regulator to supplied to the circuit and the 12volt for the relay? or is it the same source to use in the relay?
Oct 11, 2011. 6:11 AMChebog says:
Hello Sir, I have a question?. The voltage regulator IC has a Input, common, and output, is the common pin there serve's as the Ground?.
Oct 9, 2011. 7:53 PMChebog says:
sir good day again can something about relays.what relay could turn on and off a bulb with 220V and what DIODES and transistor can amplify or power up that relay?.tnx
Oct 11, 2011. 3:02 AMChebog says:
Thank you very much sir, I really appreciate it...
Oct 8, 2011. 10:26 AMChebog says:
What i mean is where do the supply of the relay goes?in order for it to function?
Oct 8, 2011. 10:25 AMChebog says:
Sir good day.can i ask you again about where do the goes in the relay is it connected on the coil to drive it? and do the ground goes is it on the common of the voltage regulator IC?please reply.
Jun 19, 2011. 5:16 AMChebog says:
good day, i just would like to ask you again regarding with the transistor.If where is the collector and emitter connected to the circuit.
Jun 24, 2011. 9:09 PMChebog says:
excuse me sir. is it OK to use any type of cellphone just like nokia phones?.or motorola phones only?.
Jun 24, 2011. 8:40 PMChebog says:
ahmm,good day sir.regarding on your circuit how about the relay how do you connect it?.because my relay comes with no diode inside.
Jun 19, 2011. 10:49 PMChebog says:
THANK YOU Sir for your reply i really appreciate it.tnx again.
Jun 15, 2011. 6:15 PMgiacomine says:
Como eu faço a ligação do celular para o circuito? E como eu faço a programação do celular (teclas)? Obrigado!
Jun 16, 2011. 8:06 AMgiacomine says:
How I make the linking of the cellular one for the circuit? E as I make the programming of the cellular one (keyboard keys)?
Jun 16, 2011. 8:08 AMgiacomine says:
How I make the linking of the cellular one for the circuit? E as I make the programming of the cellular one (keyboard keys)? Thank you!
Mar 25, 2011. 6:12 PMChebog says:
Hello Mr. Author.can i if where do the 4.7 resistors go in the circuit?because I'm trying your project and I really can't figure it out where the resistors goes in the circuit.please tell me what to do?.thank you......
Oct 8, 2010. 8:30 AMinsaneidiotic says:
hey iam trying your project to my car actually . iam not that high knowledge to do it .
iam an automobile engineer actually which makes me geek to your project...
hey please assist me with your content that u made for this project .
ill be very happy if u help me out .
since iam weak with the circuit i gonna make it through my friend to fix it in my car as considered to my car how all should i change the settings and pls help me out through mail since iam not a premium user iam not given the contents so pls do try to provide me fully.
iam from india:
my mail ID gokulnathrao23@gmail.com
contact no:+91 9790712498
ill be very helpfull if u provide me your contents of the circuit where will the major fault occur while doing this project pls assit me.....!!!!!!!!!!!!!
Mar 25, 2011. 6:06 PMChebog says:
Mr. author good day, can i ask you something where do the 4.7K resistor go in the schematic?please reply.cause I'm working on that project of yours.
Oct 19, 2010. 8:40 PMinsaneidiotic says:
It was nice hearing from you ...iam trying out in my car..... here the IC is easily available...:-) thats great of it...:-)
i have done the circuiting with my friend as explained in the picture.
sorry man that guy just did the circuiting and gave it to me. he just did not fix it to my car ... so only asking these questions.... sorry again....
My doubts .......:-)
hey man .... there is no steps after connecting to the relays, should theses realys be the command giver to the mechanism used in the car. where should i give the relays connected to...
how do i find the input from the headset of the phone it has two ends of ear peice.... which one will do for the project ?
then pls tell me about how to signal the IC through my phone this is where i hung up totally... like first call the phone number of the mobile placed in the car then should i give a combination of the numbers....... i am totally confused here ... please elaborate... how to signal the IC.... ...
hey iam at my final stage to connect to the car and work it out correctly..... if i do this i might impress my girlfriend man....... please do help me man...... whatever happens i have to do it completely.... pls help me out man.....
my face book url:
http://www.facebook.com/reflectorr
do provide me email address of yours so that i can contact u further......
Oct 21, 2010. 5:37 AMinsaneidiotic says:
thaks buddy....
will soon say u a result of what happened to my car.......:-).
Oct 19, 2010. 8:36 PMinsaneidiotic says:
my face book url:
Oct 17, 2010. 7:27 AMgormly says:
I am still amazed everytime I see a comment like this... sad.
Mar 7, 2009. 6:52 PMDiamondBack says:
"Now call your cellphone. Once it answers ..." This is suggesting that we have a second phone line on our cell plan, am I understanding that right?
Mar 5, 2010. 10:48 AMstapler117 says:
 For this use, adding a second phone to your line would be necessary. it would be better to use a prepaid phone since you wouldn't use many minutes.
Apr 5, 2010. 10:46 PMKasm279 says:
Yes but when the service expiration date nears you have to buy more minutes. Pretty soon the minutes pile up, even on my mom's phone that she occasionally uses...
Mar 17, 2009. 11:50 PMshotbythelite says:
Umm, no? No one said you needed a second plan to call your cell phone. Just call with another person's phone or your home telephone.
Aug 28, 2009. 6:21 PMAndrewNoNumbers says:
Wow you must have a lot of patience to do something like this. I gave up just reading the parts list. =]
Apr 4, 2010. 1:44 PMy2j514 says:
My plan B for when my alarm remote dies is called a key.  It works pretty well - you put the key in and the door unlocks =D
I mean sure the alarm goes off but you do the emergency override.
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:unknownpocketnerd
