Remove these ads by
Signing UpStep 1: Get your stuff.
-A mobile phone that has a hand free port. And which you can configure to self answer any incoming call. (Motorola C133, which I used has this feature).
-A hand free for your cell phone. (got it for 1 US at Waldo's 1 dollar mart)
-A car charger/adaptor for your cell phone (Waldo's to the rescue)
-The most critical of all: a CM8870 dtmf decoder IC. In Mexico, AG electronica has them. It is considered obsolete in USA, but If you can get it in Mexico, you can certainly get it in the US.
-a 3.579545MHz quartz crystal
-2 x 100 KOhm x 1/4 W resistors
-1 X 330 KOhm x 1/4 W resistor
-3 X 100nF ceramic capacitors
-7805 voltage regulator IC
-1000 uF X 25 V Filtering capacitor
-4 x 12 V Relays (I used automobile type)
-4 x BC548 or any small power PNP transistor.
-4 x 4.7 KOhm x 1/4 W resistors
-4 x 1N4001 diodes (to dissipate back emf from the relays)
-Printed circuit board (prototype board)
-A nice plastic housing (I used a discarded wireless phone base station)
Visit Our Store »
Go Pro Today »
Then use the realy's contacts as you please.
the 4.7 k resistors go between the DTMF decoder outputs and the transistors' bases.
iam an automobile engineer actually which makes me geek to your project...
hey please assist me with your content that u made for this project .
ill be very happy if u help me out .
since iam weak with the circuit i gonna make it through my friend to fix it in my car as considered to my car how all should i change the settings and pls help me out through mail since iam not a premium user iam not given the contents so pls do try to provide me fully.
iam from india:
my mail ID gokulnathrao23@gmail.com
contact no:+91 9790712498
ill be very helpfull if u provide me your contents of the circuit where will the major fault occur while doing this project pls assit me.....!!!!!!!!!!!!!
A person who engages in building this gadget needs to be experienced in electronics, or have some one with that expertice help her/him out.
The hard part is to get the IC. Newark sells it here in Mexico, but I don't know about India.
Anyway thanks for your post.
i have done the circuiting with my friend as explained in the picture.
sorry man that guy just did the circuiting and gave it to me. he just did not fix it to my car ... so only asking these questions.... sorry again....
My doubts .......:-)
hey man .... there is no steps after connecting to the relays, should theses realys be the command giver to the mechanism used in the car. where should i give the relays connected to...
how do i find the input from the headset of the phone it has two ends of ear peice.... which one will do for the project ?
then pls tell me about how to signal the IC through my phone this is where i hung up totally... like first call the phone number of the mobile placed in the car then should i give a combination of the numbers....... i am totally confused here ... please elaborate... how to signal the IC.... ...
hey iam at my final stage to connect to the car and work it out correctly..... if i do this i might impress my girlfriend man....... please do help me man...... whatever happens i have to do it completely.... pls help me out man.....
my face book url:
http://www.facebook.com/reflectorr
do provide me email address of yours so that i can contact u further......
The relays can switch on/off anything you want in your car: horn, lights, engine, locks, etc.... Just ask your friend to wire you the stuff you need to control.
Good luck impressing your fiance!
will soon say u a result of what happened to my car.......:-).
my face book url:
My plan B for when my alarm remote dies is called a key. It works pretty well - you put the key in and the door unlocks =D
I mean sure the alarm goes off but you do the emergency override.
What was the voltage of the ceramic capacitors?
Since there were differences in your build, can you provide the actual schematic used for your board?
I was able to locate a good source for the CM8870 dtmf decoder IC at http://www.dpcav.com
This project has inspired me to make a similar system that will (hopefully soon) become another 'structable here! :D Thank you!
