In this Instructible, I will tell you how to get the most out of your Dremel, from proper use of attachments, to safety and other various tricks I have picked up.
Remove these ads by
Signing UpStep 1Parts of Your Dremel + How to Attach and Detach Bits
By default, your Dremel will come fully assembled, minus a bit in the collet. However if you find yourself taking the parts off to clean them, you may want to know how to reassemble them. First screw on your rubber collar, this is shown in the first picture. Next insert the collet (Picture 2) and finally the cap (Picture 3). While this is still loose, insert your bit (Picture 4), hold down the shaft-stopping button and tighten the screw cap with the wrench.
Once the cap is fully tightened, you are ready to use your Dremel.
After that it was a dremel every 1/2 year. I switched to a Black and Decker RTX No troubles at all. Upside, I took apart my old Dremels and stuck the shafts into old screwdriver handles, make wonerderful clamps and third hands for holding small parts.
--Safety is indeed first and foremost; placing the eye-protection blub at the end is actually a good idea. People tend to remember best what they've seen/heard last.
--The wire brush tends to lose individual wires as it's used--another good reason for eye protection. Use this attachment in a location where the bits of wire won't get embedded in undesired places such as bare feet.
--The non-reinforced cutting discs can be strengthened by wicking a few drops of thin CA (super-fast) glue into the disc. Hobby-store CA is generally superior to the stuff sold in most big-box stores.
I finally called Dremel, and they very kindly sent me two screws. It took two weeks and they arrived in this bubble envelope that could have held 2,000 screws. Lesson of the day: It's faster and cheaper to buy a new mandrel - it comes with a screw.
Oh, and great instructable too :)
RL
the glasses-style eyeshields leave a large gap that beckons crap to your lower lids
I learned this the hard way and as a result, had to spend a lot of time digging fiberglass out of my lower lids.
VERY IMPORTANT:fiberglass is encapsulated and pushed out of the body eventually, but carbon fiber will continually dig through your body, creating scar tissue as it goes.CF Lovers: Effective Eye Protection FTW!save your sight homies!
great Ible, very useful!
Hint: Remember the bit and the brass insert collar must match in thickness.
If you already double checked this, then it could be a stipped cap screw or threaded collar.
I think that just about might cover it.
www.dremeleurope.com/media_all/download/accessories-overview.pdf
Was it anything like these? Forgive the small size and crap quality!
The "Large" preference on my favourite image search engine yielded few results unfortunately.
http://toolmonger.com/wp-content/uploads/2008/05/Cleaner.jpg
http://www.matcotools.com/ProductImages/spc1.jpg
Ciao.
