3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Get the Most out of your Dremel
Step 2The Dremel's Bits
The Dremel\
Almost any Dremel you buy will come with several different bits. Each has its own specific use, and each must be used correctly in order for them to last. Here I will explain the bits I own, and their various uses. I wish I knew how to do those nifty bullet type things, but until then:
Cutting Bits:
Fiberglass Cutting Disc - I love these guys, they are the largest cutting bit you can get for a Dremel, and they tend to last for a good while before breaking. Advantages include deeper cuts and they're able to cut stronger material, such as metal and ceramic. Disadvantages are that refill packs are about $10 for five of them.
Standard Cutting Disc - Also decent for metal, most replacement packs come with many for cheap. They break often, and I've been nicked by flying disc-shrapnel before. Used for all-purpose cutting. Use these before your nice fiberglass ones.
Grinding Bits:
Carbide and Standard Grinding Bits - Both essentially the same, the carbide bits are designed more for metal, however the standard ones work well on it too. Use these whenever you have to take down sharp edges on something. The small carbide one is decent for drilling holes through metal, just make sure you center punch it with a nail or something beforehand.
Various Sized Sanding Bits - Almost self explanatory, use these for sanding wood inner corners and edges. Note that these will break very quickly if you attempt to use them on metal. The sanding discs are used primarily for flat surfaces and edges, you could call these disposable, refill kits are cheap and plentiful. More information on how to change and replace these later.
Carbon Steel Brush Bit - I love this one as well. Very useful for cleaning out tools and taking paint off anything. Scrapes away delicately on a lower setting and more vigorously on a higher setting. Can be used in place of a larger wire brush wheel to clean files.
Drilling Bits:
Drill Bit - When I don't want to go out back to my drill press or get the DeWalt, this is a worthy substitute. Whenever drilling into anything, be sure to center punch it with an awl or Leatherman tool.
Brush Bit - Not truly a drilling bit, but still worthy of mention. Can be used for....well for brushing things. Not the most useful attachment, but it's handy to have...sometimes.
9 comments
Aug 18, 2010. 7:02 PMdrdanielalvarez says:
The Dremel Europe site has great tips and videos. Important tips on cutting discs: the 409 (not fiberglass reinforced) should be used double, that is 2 discs together. The 456 (fiberglass reinforced) should be used with a a washer on each side. Click on "Training Videos". http://www.dremeleurope.com/gb/en/download
Jan 13, 2011. 2:26 AMcarpii says:
Thanks for posting these. I just got a wireless dremel, but I was really disappointed with the lack of explanation on how to use any of the attachments, or even the SpeedClic system. I didnt think to look on their website, cheers
Oh, and great instructable too :)
Mar 5, 2010. 10:01 AMcsiquet says:
I downloaded the bits' chart from the Dremel site, I had it printed in A3 size and plastified. Very useful.
www.dremeleurope.com/media_all/download/accessories-overview.pdf
Dec 14, 2009. 7:18 PMEvilthingamabober says:
Nice, what's the melted solder for? It kooks really useful.
Jun 14, 2009. 9:45 PMrhoaste says:
Sorry to sound a bore, but it's essential to wear safety glasses when using the cutting disks in conjunction with the Dremel or similar tool. When the cutting disks break (and I can assure you they will), fragments fly everywhere at colossal speed. If one of these hits you in the eye- it's game over. Be safe!
Aug 22, 2009. 8:35 PMcdousley says:
you need glasses just for the dust their essential with cutting wheels
Jul 7, 2009. 11:40 PMABLACKX says:
If you read the whole Instruct able you'll see the the last step is about safety , but thanx for pointing that out :) "Safety First"
Aug 18, 2009. 5:01 PMosgeld says:
Im sorry but that just tickles me, "Safety First" but ironically its on the last page
Aug 18, 2009. 11:56 PMABLACKX says:
Your comment is a killer , I'm now left speechless :) you're %100 right ,good one
Aug 13, 2008. 12:31 PMjack8559 says:
The bit you call a cleaning stone is actually a shaping stone and is glued in place to keep your fingers from being ground down when using it. If you apply pressure to it, it eats away at the stone thus'cleaning' it or shaping the stone to whatever shape you desire. They tend to fly away at times and get hot when used, that's why they are glued in place. If you use an air die grinder with stones, you'll appreciate the fact that you have a holder for when the stone slips off the cleaning stone and grinds your finger/nail/hand.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:Firebert010
I study engineering at Virginia Tech. Long time instructables fan.
