Step 3Specific Bit Uses
Cleaning a pair of needlenose pliers with the carbon steel brush bit: (Pictures 1-5)
My overused pliers gather lots of crud fast, so I often use my carbon steel brush attachment to clean them out. This task is simple enough, and requires little time to improve the performance and grip of your pliers.
Start by attaching the bit to the Dremel.
Put it on a low setting and start brushing parallel to the plier grooves.
You will find this improves the pliers grip greatly.
Changing sanding sleeves on a sanding block mandrel: (Pictures 6-9)
If you've worn out your current sanding bit's sanding sleeve, it may be time to replace it with another. To do this, start by taking the sanding bit out of the Dremel if it isn't already. Remove the small screw at the top of the bit, and slide the rubber part off the shaft. The reason we do this is because of the way the bit is made, the sleeve can only be removed when it is off the shaft.
Once the rubber block is removed, slide the sanding sleeve off of it and throw it away if you're replacing, or slide a new one on if you're putting it on for the first time. After this simply slide the block back on the shaft (making sure both the washers are there) and screw it back in tightly.
Polishing wheel use: (Pictures 10-15)
In order to install a polishing wheel, you first need to remove a different disc from the interchangeable disc mandrel. Take one of the cutting wheel mandrels and unscrew the screw at the top. remove the disc from the screw and insert the polishing wheel through the screw. Thread the screw onto the shaft of the mandrel and tighten snugly.
Once completed turn your Dremel on a low setting and apply some polishing compound. You can use this wheel and compound mixture to polish any type of metal. Below I've included a sample of a pair of scissors that I've used the compound on. Notice the great shiny lighting and visible difference from the rest of the tool.
the glasses-style eyeshields leave a large gap that beckons crap to your lower lids
I learned this the hard way and as a result, had to spend a lot of time digging fiberglass out of my lower lids.
VERY IMPORTANT:fiberglass is encapsulated and pushed out of the body eventually, but carbon fiber will continually dig through your body, creating scar tissue as it goes.CF Lovers: Effective Eye Protection FTW!save your sight homies!
great Ible, very useful!
