Laptops' CPU and GPU overheat a lot sometimes, and If you don't want to watercool, you can add fans! In this I'll be showing you how to make your own laptop cooler! You'll need the following:
Wire
Computer Fans
Some kind of building material (Try for plexiglass or Lexan)
Soldering Iron
Solder
SPST Switch(s)
DC Power Supply
All of these you can obtain through eBay or the dump. I got my soldering iron, solder,switches, and wire from Radioshack, the fans and DC power supply from eBay. The links are below:
DC Supply - http://cgi.ebay.com/AC-100-240V-DC-12V-Adapter-Converter-Power-Supply-New-/270575442566?pt=LH_DefaultDomain_0&hash=item3eff8d9a86 (It has 1000MA of power AKA: 1A)
120mm Fan
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190468751856&ssPageName=STRK:MEWNX:IT (Not the best airflow, but it was cheap, if you want a better fan go buy one.)
Now, the number of fans you want to use is up to you, just make sure you have enough AMPS on your supply.
Remove these ads by
Signing UpStep 1: Step 1-Preparing
zazenergy says:
Mar 17, 2011. 3:20 PMReply
Not Nice
Visit Our Store »
Go Pro Today »
