Getting instructable counts. (continued)
Picture of Getting instructable counts. (continued)
Screenshot-eddie@oesrvr104: ~.png
Notice: Becuase Instrucables has changed their web pages again, this instructable will not work. I am working on a fix.
In the last instructable we just displayed the data. Now we will modify the code and then use the code to get the data and the counts for importing into a spreadsheet . Sorry I did not use an icon. You can do that.
Original data:
idata: (not do not type in "[data]" or [/data] or you will get an error)
[data]
http://www.instructables.com/id/Program-an-ATtiny-with-Arduino/
http://www.instructables.com/id/Gut-Check-Fridge-a-Tweeting-and-Facebooking-Fri/
http://www.instructables.com/id/Air-quality-balloons/
http://www.instructables.com/id/Sun-Bottles/
http://www.instructables.com/id/Wrap-around-workbench-under-100/
http://www.instructables.com/id/Solar-PV-tracker/
[/data}
We now have a modified program:
gidata2ss.sh:
[code]
# Instructablesnumbers catcher
# Assignments
szAnswer=$(zenity --file-selection --title="Select a iurl file to read")
datafile=$szAnswer
outfile="inumdata"
# the date
tmon=$(date +"%b")
tday=$(date +"%d")
echo "The views for $dj on $tmon $tday:" > $outfile
# Data input
while read line
do theurl=$line
# uncomment the following line if you want to see the url and or views
echo "$theurl"
# get total views
# elinks "$theurl" | grep "Total Views"
# get all the info
# elinks "$theurl" | grep Views
# just get numbers
elinks "$theurl" | grep -m 1 "Total Views" | cut -c 16-25 | sed 's,\,,,g' >> $outfile
done < $datafile
zenity --text-info --filename=$outfile
[/code]
Run program to get data.
Start new spreadsheet.
Copy and paste numbers into spreadsheet (use fixed with and special numbers)
Add column titles
Copy paste URL's (with fixed length.)
Save and done.
Included a short movie to show how it works.
Update:
Wrote a new version of the script and it should work better.
[code]
# Assignments
datafile=$szAnswer
outfile="inumdata"
# the date
tmon=$(date +"%b")
tday=$(date +"%d")
# Data input
while read line
do theurl=$line
echo "$theurl"
# echo -n "$theurl'" >> $outfile
# get total views
curl -s "$theurl" | grep -m 1 "hits-count" | sed 's/[^0-9]*//g' >> $outfile
done < $datafile
[/code]
Partial temp fix
# Assignments
datafile=$szAnswer
outfile="inumdata"
total=0
# the date
tmon=$(date +"%b")
tday=$(date +"%d")
# Data input
while read line
do theurl=$line
echo  "$theurl"
# get total views
# count=$(elinks  "$theurl" | grep -m 1 "hits-count" | sed 's/[^0-9]*//g')
count=$(elinks  "$theurl" | grep -m 1 "views" | sed 's/[^0-9]*//g')
# let total=$total+$count
echo "$count" >> $outfile
done < $datafile
# echo "total: $total" >> $outfile
Yet another temporary fix.
While looged in:
# Assignments
datafile=$szAnswer
outfile="inumdata"
total=0
# the date
tmon=$(date +"%b")
tday=$(date +"%d")
# Data input
while read line
do theurl=$line
echo  "$theurl"
# get total views
done < $datafile
Get favs by:
# Assignments
datafile=$szAnswer
outfile="inumdata"
total=0
# the date
tmon=$(date +"%b")
tday=$(date +"%d")
# Data input
while read line
do theurl=$line
echo  "$theurl"
# get total views
count=$(elinks  "$theurl" | grep -m 1 "favorites" | sed 's/[^0-9]*//g')
done < $datafile
Computothought (author) 2 years ago
Updated code in progress for the new format. Let me know if it does not work for you. If you have instructables html that are not updated, then it may miss a count.
[code]
outfile="inumdata"
# the date
tmon=$(date +"%b")
tday=$(date +"%d")
# Data input
while read line
do theurl=$line
echo "$theurl"
# get total views
curl -s "$theurl" | grep "hits-count" | sed 's/[^0-9]*//g' >> $outfile
done < $datafile
[/code]
Computothought (author)  Computothought2 years ago
At least the numbers are more accurate now than with the old web pages they used.
sunshiine2 years ago
Again thanks for sharing!
Sunshiine
Computothought (author)  sunshiine2 years ago
Thanx for the kind comment!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
