Getting instructable counts.
Picture of Getting instructable counts.
Note with the change in the way instructables.com now does web pages, I will probably have to redo this instructable.
Lets say you wanted to know how several instructables are doing. Did not take the time to make it with a gui. that is your homework. Just picked a few instructables from the first page as an example. You will want to create a data file with the urls or the web address of the instructables you have chosen. Right click on the links and copy link location and then paste it in your editor using the data file(Please see the prior instructables on page scraping if you have any questions).
idata: (Note: do not type in "[data]" or [/data] or you will get an error)
[data]
http://www.instructables.com/id/Program-an-ATtiny-with-Arduino/
http://www.instructables.com/id/Gut-Check-Fridge-a-Tweeting-and-Facebooking-Fri/
http://www.instructables.com/id/Air-quality-balloons/
http://www.instructables.com/id/Sun-Bottles/
http://www.instructables.com/id/Wrap-around-workbench-under-100/
http://www.instructables.com/id/Solar-PV-tracker/
[/data}
Then you need to create a program file to collect the data via web scraping. I did not go to the trouble to make it gui for simplicities sake.
iget.sh
[code]
# Instructablesnumbers catcher
# Assignments
datafile="idata"
# the date
tmon=$(date +"%b")
tday=$(date +"%d")
echo "The views for $dj on $tmon $tday:"
# Data input
while read line
do theurl=$line
# uncomment the following line if you want to see the url and or views
echo -n "$theurl"
# get total views
# elinks "$theurl" | grep "Total Views"
# get all the info
elinks "$theurl" | grep -m 2 Views
# just get numbers
# elinks "$theurl" | grep "Total Views" | cut -c 16-25
# Un remark the next line if you want it to be a bit more readable
# echo ""
done < $datafile
[/code]
Make it a program:
$ chmod +x iget.sh
Run it:
$ ./iget.sh
The views for on Oct 06:
$ _
The following will save everything to a file if your want.
$ ./iget.sh >> datafile
A real time saver if you have many many instructables and do not want to go through each page to get the data. Follow up instructable: http://www.instructables.com/id/Getting-instructable-counts-continued/
Warning: Data may not be always up to date.
Mswindows:
Software needed:
Browser:
Elinks:
http://www.paehl.com/open_source/?TextBrowser_for_Windows:ELINKS_an_other_textbrowser
Grep
Grep from unxutils
http://downloads.sourceforge.net/project/unxutils/unxutils/current/UnxUtils.zip?r=&ts=1331135481&use_mirror=iweb
Qbasic from Microsoft.
http://www.microsoft.com
Winzip:
http://www.winzip.com/win/en/downwz.htm
You will want to create a datafile with the urls of the instructables you want to check on:
[data]
[/data}
Here is the code. you will want to make a program file called scrape.bas.  You will run it from qbasic.
scrape.bas(just use the lines between [code] and [/code])
[code]
OPEN "idata" FOR INPUT AS #1
while not (eof(1))
INPUT #1, a$
PRINT a$
b$ = "elinks " + a$ + " | grep Views:"
SHELL b$
PRINT
wend
close #1
system
[/code]
Note: If you have freebasic for mswindows or freebasic for linux. the code will work on either machine. I suppose it would work on a Mac also if you had the appropriate basic language compiler. Love portable code!
Once you have created all the files and the prorgams you downloaded are accessible from the directory, you should be able to get a print out.
c:\> qbasic /run scrape.bas
Afterthought: probably could of used lynx instead.....
Temp fix:
# Assignments
szAnswer=$(zenity --file-selection --title="Select a iurl file to read")
datafile=$szAnswer
outfile="inumdata"
total=0
# the date
tmon=$(date +"%b")
tday=$(date +"%d")
echo  "The views for $dj on $tmon $tday:" > $outfile
# Data input
while read line
do theurl=$line
echo  "$theurl"
# echo -n "$theurl'" >> $outfile
# get total views
# count=$(elinks  "$theurl" | grep -m 1 "hits-count" | sed 's/[^0-9]*//g')
count=$(elinks  "$theurl" | grep -m 1 "views" | sed 's/[^0-9]*//g')
# let total=$total+$count
echo "$count" >> $outfile
done < $datafile
# echo "total: $total" >> $outfile
zenity --text-info --filename=$outfile
sunshiine2 years ago
Thanks for sharing all your hard work! This is valuable information! Have a splendorous day!
Sunshiine
Computothought (author)  sunshiine1 year ago
Thank you and your welcome!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
