Getting Rid of the Auto-dim on a Clock Radio
Published
Introduction: Getting Rid of the Auto-dim on a Clock Radio
One of my bugbears has been the auto-dim on my clock radio: you know, the thing that causes the display to dim when it's dark so it doesn't keep the sleeper awake. Trouble is, my eyesight is quite bad so if I wake up in the dark the clock's display is so faint that I cannot read it.
I intended to Sort This Out.
And here's a caveat: I'm located in the UK, so the clock radio I'm using (Pure Siesta Mi) will probaby not be available where you live, but I reckon that pretty-all most manufacturers will use a similar system.
The first thing it to find out how the light or dark is detected.
Step 1: Finding the Light-detector
I could tell that the light-detector was on the top of this particular clock becasue the display dimmed just be covering it with my hands. I then used a coin to cover various holes around the speaker until I found the one which hid the detector (I've circled it in the picture).
This clock was easy to open with just four screws in the bottom. Once they were out a small screwdriver was used to crack the case open.  The insides are very neat, with one circuit board containing everything, a display, and a loudspeaker that just lifted out.
And there's the light-detector, in this case a photo-diode.
How do I  know it's a photo-diode?
Well, the biggest reason is that it looks like one, but the tell-tell markings of 'D1' next to it on the circuit-board kind-of gave it away. The other reason is that it's a lot cheaper to use one of these beasties than it is to use a LDR (light-dependant resistor).
So, what is a photo-diode ...?
Step 2: Photo-diode Dimming, and How to Eliminate It
A photo-diode in this kind of circuit acts like resistor, so the amount of current it passes is proportional to how much light it is receiving: a small current when it's dark, and more as it gets lighter until it passes all the current and acts just like a short-circuit (or a wire).
To check that this is how the circuit worked I covered the phoo-diode so the display dimmed, then shorted out its pins on the circuit-board with a screwdriver. And sure enough, the display came back to full brightness.
And so I put a big blob of solder between the pins! Job done, put the case back together, everything hunky-dory.
But .... be careful with other makes of clocks. I knew that the display on this one was being switched via the main processor because it switched the display between discrete levels of dimming, but other clocks may be not be so intelligent. Use a resistor to bridge the photo-diode if you're not certain.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    2 Comments
    Thanks for this guide. Came in handy for the other Pure Siesta with a front mounted light sensor. The default light level at night was utterly ridiculous, barely visible. Staggering here is no option to disable it in the menu!
    Simple fix without solder, I got some speaker wire which i stripped and wound tight then poked it in between the "stems" (not sure if that's the right term) of the diode, which was held in place on the front of the unit, then wrapped it around the stems to complete a permanent circuit. Best part is it is completely undetectable if it goes back under warranty as I can just remove it with ease. Your guide didn't directly apply to my radio but it was definitely pointing me in the right direction. Glad I've resolved his as the night time brightness was so bad it was a deal breaker and I was going to return it. Thanks again!
