Getting started in LSL scripting in Second Life
Step 1What is LSL?
LSL is the Linden Scripting Language. This is the language all scripts in Second LIfe are written in. Its structure is based on Java and C. Scripts in Second Life are a set of instructions that can be placed inside any object in the world, or any object worn by an avatar, but not inside an avatar. They are written with a built-in editor/compiler which we will access in step 2.
One thing that makes LSL unique is it's heavy emphasis on "States" and "Events". A door can be "open" or "closed" and a light can be "on" or "off". A person can be "hyper", "calm", or "bored". Many real life objects have "states" and the same can be true for LSL programs. Minimally a script will have one state, the default state.
An event can be thought of as a "Trigger". Events are not user defined in Second Life but rather predefined in LSL. One called Touch_start(), will trigger the code in it when the object running the script is touched. So the minimum LSL program must have one state with one event in it. Here is a look at a minimal program in written in LSL that can loosely be translated as...."When I am in the default state, and I am touched, say "Hello World" on channel zero".
default
touch_start(integer total_number)
llSay(0,"Hello World");
WHAT CAN I DO WITH SCRIPTS?
Scripts can make an object move, listen, talk, operate as a vehicle or weapon, change colour, size or shape. A script can make an object listen to your words as well as talk back to you, scripts even let objects talk to each other.
The most basic object in Second Life is the "Prim" or primitive, the basic building block of all objects you can build in Second Life. When several prims are linked, they can each contain a script which speaks to the rest of the object via Link Messages. These are faster and more private than having objects "chat" or email each other. These are beyond the scope of this tutorial and we will instead focus on single scripts in a single prim.
Scripting is harder to learn than basic object manipulation, but is very rewarding once you make progress.
If you've built in Second Life, everything you can define in the edit window can be defined in a script. All interaction you see between objects or between avatars and objects is via scripts.
Learning more about the world and building model is vital to some aspects of scripting, thus I'd recommend a good foundation in building as you learn to script.
1 comment
Dec 21, 2006. 11:09 AMmaxspawn says:
I saw in a called site www.2lifeblog.com, some scripts to download; Basic Motorcycle Script, animated texture simple, final flight 2.2, and more, also it is possible to download the complete manual of scripting for Sl. Regards: Massimo
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Blueman
Hey all, this is Blueman Steele. I don't log in much now but want to try to put some of the many things I learned in Second Life here on this site.
