Step 3Getting Connected
After powering up the VMUSIC2, insert your USB drive with the FTRB.FTD file on it.
You should see the lights blinking. It will take about 20-30 seconds to program the new firmware. Do not remove power while it is flashing or you will have to go the more expensive and complicated route I went through (or worse -- you loose the bootloader completely.) The light should glow RED for a second or two and then stay a steady green once flashing is complete. Don't be impatient. It will be pretty obvious while it is programming. Normally, there is no activity light on the USB flash drive upon start up. The lights will be going crazy while it is programming and verifying.
Disconnect the 5V from the VMUSIC module.
You are now ready to hook the rest of the signals up and start talking to it with hyperterminal.
This is where a bunch of information is unclear in the documentation. First of all, the VMUSIC2 UART interface is 3.3V logic. You will need some type of converter for your connection. I am not going to go into too much detail on how to do this, because there are many options. One of the easiest is to purchase a Nokia DKU-5 cellular phone data cable and modify it by cutting off the Nokia connector. This cable is a USB to RS232-TTL3.3v cable based on the FT232R. There is no CTS or RTS handshaking signals in this cable, which is one of the reasons that we modified the firmware for no flow control.
There are several articles on the internet that tell you how to modify this cable and it is useful for many purposes. It doesn't matter what converter you use as long as it is designed for 3.3V TTL, not 5V. Prepare for the next step by making sure that you have installed the drivers for your converter (if USB.) It should be showing up in device manager. Make a note of the COM Port assigned to it.
If enough people have a problem with this step, I will create a separate instructable based on the nokia cable. But this cable is extremely popular in many modding communities and the mod is pretty well documented. I am using a different (more expensive) converter right now and do not have access to my nokia cable ATM, otherwise I would add it here.
UPDATE: Found a good article explaining different options and sources to cheap cables. I don't know how I missed it, but the TTL-232R-3V3 from FTDI is practically made for this purpose. Check out thisthis link for other options (you might even have something lying around)
Before connecting anything else to the VMUSIC2, again, make sure the power is not connected.
Connect the RXD on your converter to the TXD on the VMUSIC2
Connect the TXD on your converter to the RXD on the VMUSIC2
Connect the GROUND on your converter to the GROUND on the VMUSIC2
Connect CTS on the VMUSIC2 to GROUND (This is not optional. You will be able to send commands, but you will receive no responses if you do not connect this signal to ground.)
RTS can be left disconnected
RI is left disconnected
Now would be a good time to load the flash drive up with some MP3s (I renamed mine 1.mp3, 2.mp3, etc... to make it easier) and also delete the FTRFB.FTD file from the flash drive. The firmware can only read DOS filenames. This means 8 characters for the filename and 3 for the extension. I believe you can leave off the extension and just use all eleven characters for a filename, but that might break in future firmware, so I don't advise it.
Leave the 5V line disconnected. We will be connecting it again in the next step.
I want to make a few final notes regarding this section just to make it complete, as it will not be relevant in future steps:
If you do have a converter capable of RTS/CTS flow control, this is actually preferred. If you ever need to reload the firmware the hard way, this is absolutely necessary. The bootloader only supports this mode. There are two reasons that we turned this off, however. The first being that most people are going to find cheap cables that do not support this, and programming a microcontroller to handle RTS/CTS flow control is a bit more complex and requires more IO and software overhead. Most libraries do not support it, so just turn it off. If you run into trouble flashing your firmware, you are going to need an RTS/CTS capable serial converter to recover it, though.
To use RTS/CTS flow control, swap the two signals between devices. This means RTS on the converter should be connected to CTS on the VMUSIC2 module, and vice versa.
Finally, RI is Ring Indicator, which can be pinged to wake the VMUSIC2 module out of standby. We will not be using it here and it is not used in firmware recovery. Just leave it unconnected.
The pinout of the VMUSIC2:
Being a newbie, I'm having a little trouble with this step. I managed to load the firmware, but I'm not sure in what direction I should head next (regarding the TTL-232R-3V3). I do have a USB adapter (link) that I bought with a BASIC Stamp kit, from Parallax, that looks like it's based on the FTDI chip. Can I use that adapter?
Thanks again,
Andy
