3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Getting started with the Maxbotix sonar sensor - quick start guide
The MaxSonar EZ1 provides very short to long-range detection and ranging, in an incredibly small package. It can detect objects from 0-inches to 254-inches (6.45-meters) and provides sonar range information from 6-inches out to 254-inches with 1-inch resolution. (Objects from 0 inches to 6-inches range as 6-inches.) The interface output formats included are pulse width output (PWM), analog voltage output (Vcc/512 volts per inch), and serial digital output (9600 baud). A good sensor for when a Sharp IR distance sensor won't cut it.
Step 1Are you a pro? Go straight to the datasheet...
If youre a pro cut straight to the data sheet- if not, here's a quick start guide on using the Maxbotix sonar sensor&
10 comments
Jul 7, 2011. 8:28 PMahernandez15 says:
is their any way you can make a trigger with a tela photo lens. but remeber the light that triggers it is emeral and its about 25 feet away if you could help out post back.
Oct 10, 2009. 10:55 PMDetarmstrong says:
What advantages/disadvantages do the other pin outs offer?
Oct 31, 2009. 1:53 PMDetarmstrong says:
The preview feature assumes the view actually works correctly...
http://www.maxbotix.com/MaxSonar-EZ1__FAQ.html#Tell_me_how_the_serial_pulse_width_and_analog_voltage_outputs_compare
Oct 10, 2009. 10:57 PMDetarmstrong says:
Nice diagram. What program did you use to generate it?
Oct 25, 2009. 3:13 PMDetarmstrong says:
Aug 24, 2009. 9:57 AMking_zilla says:
like that green circle thing on a submarine that shows where things are?
Aug 5, 2009. 5:32 PMMANIAC says:
so what does this actually do?
Aug 12, 2009. 9:19 PMkicker109 says:
its SONAR (sound navigation and ranging) it is like what bats have to see because they are sort of blind.... a,k.a Uber- Hearing
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
234
Author:adafruit(Adafruit Industries)
All-original DIY electronics kits - Adafruit Industries is a New York City based company that sells kits and parts for original, open source hardware electronics projects featured on www.adafruit.com ...
more »
