3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ghetto Muffler Fix
Ghetto Muffler Fix
DISCLAIMER: Like all of my Instructables; this contains adult humor.
This is what happens when your exhaust is horribly rusted (from someone parking it for long periods in wet grass….)
And you bottom out on snow ruts on residential roads (cause the city you live in is stupid and too cheap to plow), denting said rusted pipe..
And then you hit a big chunk of snow that fell off a mini-van in front of you (cause that’s just they way things happen to you).
Step 1Step 1
Step 1
Since I grew up in the Ghetto of Edmonton (yep that’s right the upper middle class suburbs of the West End).
 Like multi-millionaire J-Lo, I know all about keeping it real….
6 comments
Apr 14, 2010. 8:47 AMyo man says:
crazy cool fix up man
Dec 9, 2009. 5:39 AMfritsie123 says:
If this works for you, great! Where I live (Europe) this would get you a fine so large you could have replaced the whole exhaust system several times over.
Somehow it is frowned upon having exhaust gasses escaping under the car and potentially coming in through holes in the floor.
Anyway, the sound is also regulated here, make to much exhaust noise and, yep, that's another hefty fine.
But as said, rules depend on location, so if this is legal in your community, it is a cheap fix.
Mar 17, 2010. 6:27 PMTreknology says:
In a country where salted highways are a common means of clearing snow and drastically shortening the life-span of a motorvehicles, such a repair should be legal and acceptable, although I do agree with suggestions further down that it should be a tighter fit to prevent discharge under the vehicle.
Good job!
Dec 9, 2009. 9:58 AMnnygamer says:
With prices on just the small parts for a car I don't blame you. Years ago I needed a muffler on my beat up Tahoe, but I was broke at the time. I ended up making a muffler from material I had around. Clamps, some old exhaust pipe with holes drilled in it, fiberglass insulation and a small stove pipe.
Dec 9, 2009. 5:04 AMHarveyH44 says:
I did a similar repair on my Firebird, using a dog food can.  Just remove both ends, use tin snips to cut length-wise, hose clamp on both ends.  Lasted a couple of years, just replaced the can when it blew out.
Dec 9, 2009. 1:24 AMironsmiter says:
Stainless steel hoseclamps are your friend!
Two hose clamps(one for each end of the patch) should drastically increase your out-the-muffler flow. Dunno about your mad horsepower gains, but it should at least be quieter.
not sure what a zoodle is... or wt sort of can it comes in, but as long as the base metal is steel, you should be good fr a couple thousand miles :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:houseoexcess
