3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ghetto Programming: Getting started with AVR microprocessors on the cheap.
Step 8Get your first demo circuit set up
Put the chip in the cradle. You'll notice that the pins all angle outwards a bit when the chips come from the factory. Bend them in (gently) on the table so that they're all even and parallel. Then it fits in the socket nicely.
Notice the alignment of the chip. The little dot marks pin 1. Is it where pin 1 should be?
Plug in your 5v power and the programmer cable. Plug the programming cable up to your computer.
Take a Ghetto Blinkenlight and put it between pins 8 and 10 so that the resistor (negative) is in pin 10, the ground for the chip.
7 comments
Mar 10, 2010. 10:20 PMbha123 says:
 guys where can i find these micro controller and ics actually i am IT student but for my project i need them can any body suggest where can i get them
Jun 20, 2010. 7:53 AMSimpson_jr says:
Ebay...
Mar 10, 2010. 10:22 PMbha123 says:
 sorry to specify in banglore ,india where can i find these components
Mar 23, 2010. 6:50 AMcdousley says:
allelectronics.com
ebay
Sep 5, 2009. 8:53 PMenxion says:
Finally got it working for the atmega8. It helps not to be a sloppy soilderer. Thanks for this tutorial.
Jul 5, 2009. 12:27 PMMandela says:
After doing this, can me remove the ATTINY2313
and making something like this ?
http://www.instructables.com/id/Programmable-LED/
Aug 24, 2009. 12:22 AMgodfreyandthandi says:
yes
Oct 21, 2008. 1:17 PMpurpulhaze says:
Is tapping into the usb as a power source safe for the chip? I know you posted 5v but I believe usb is rated a lil over 5v.
Jun 4, 2009. 6:49 PMpsymansays says:
USB is actually exactly 5VDC, regulated power.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
95
Author:The Real Elliot
