loading
Step 12: Put it all together.
Now loosen the outer hoop as much as it will go. Hold the 3 bent wires on the inside of the outer hoop and insert the inner hoop. This will be quite tricky and unless you have 3 hands, you might need a friend to help. Or hold them all in one hand while you fiddle with the inner circle. Once you have the inner circle in place, tighten the outer circle a little bit. Then arrange the wires so you have them at 10, 2, and 6 o'clock. Tighten the outer hoop as tight as it will go. Then insert your mic into the circle. CAREFULLY adjust the screen so you have about 1-2" between the mic and the screen itself. Then you're done!
Hey, this is a great instructable and is very informative. Just one thing is missing... pictures! It really helps a lot when trying to follow directions so you should consider taking some photographs. Once you do that and leave me a message when you have so that we can publish your work. Thanks! Thanks for the cool instructable and we hope to publish this soon!
Great idea! Now if only I hadn't already gone out and bought one I could have saved myself &pound;50!<br> <br> <a href="http://www.evolutionmastering.com" rel="nofollow">Evolution Mastering</a>
Great idea! Now if only I hadn't already gone out and bought one I could have saved myself &pound;50! <br> <br>www.evolutionmastering.com
that was very simple, great idea and i'm going to use it. There's some other video with a guy who made his out of wood and rubber and all this other crap and the whole time I'm thinking... couldn't you just use a damn coat hanger?
About This Instructable
5,604views
14favorites
License:
More by hgospod:How To Hem Jeans How To Remove Brass From A Spent Shotgun Shell Tea infuser
Add instructable to:
