3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ghettoblaster MP3 player installation
Step 6Wire in the Jacks
Wire in the Jacks
Next i found a blank spot on the board to rewire the 3 pronged jack. This is so that if I want to tear the boombox open for whatever reason I can easily detach the front of the box. This is where I will connect my "headphone" jack to.
On the other side of the board I tried to determine where to wire my audio on the Function Selector switch. I was going for connecting to the tape function bypassing the amplifier for the tape deck. Eventually I abandoned this approach and just cheated and wired up to the Aux Line Input RCA jacks.
It would have helped to have the repair manual for this boombox but I didn't get that until I had finished the project. If only I had been a little patient who know how it would have turned out. All my attempts to use the tape deck circuit resulted in underlying noise that was simply avoided by going for the Aux Line In. Perhaps I could have figured out how to not only disconnect the motor but also disconnect the tape amp it would have been different.
The early reason I decided to go with the Aux Line in instead of the Tape Circuit was I wanted to use the motor power source for the charger. That changed later along the way as well. Now the Tape Selection serves as a total power down for the boombox.
Here's an instructable that successfully uses the tape circuit to play and charge an iPod http://www.instructables.com/id/PLAY-AND-RECHARGE-IPOD-USING-OLD-BOOMBOX---Hints-a/
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Kepster
