3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ghettoblaster MP3 player installation
Step 7Reroute side buttons to the front of the Boombox
Time to void the warranty on the MP3 player... Carefully figure out how to open the case of the MP3 player. Usually carefully twisting the player will get it to split open. Determine where the fasteners are in the case and carefully unsnap them. Prying on the edges of the split will chew up the side (not that anyone will see the sides) you may possibly slip and damage the inside of the MP3 player or slip out and slice your hand. Some how I managed to avoid damaging anything.
Now with a micro-tip on your soldering iron and use extreme precision to solder your button wires to the solderpoints inside the MP3 player. If you splash any solder or overheat the components you will soon be chucking your MP3 player in the trash or scrapping it out for parts. I experimented on a $11 MP3 player that I burned up prior to this step when working on the whole charger set up.
The best place to thread the wires is through one of the openings for side buttons you displaced in this installation.
Make sure you seal up the MP3 player again for added protection before you finish installing it into the deck.
By the way...the MP3 player is precisely lined up and hot glued into the cassette carriage.
4 comments
May 6, 2010. 1:14 PMicanhaszombie says:
 What if you retained the open/close functionality of the tape door and simply used a cabled connector on the inside? That way you could simply open the door and take the player out to access the buttons, and slide it back in and close the door. If theft is an issue a simple tab-style lock could be installed to keep the door closed unless you want it open
Feb 2, 2010. 2:08 AMsamuraiclinton says:
I better idea would be to make a docking station for the Zen instead of integrate it with warranty-voiding modification.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Kepster
