Step 8The SD card Drive Dilema
Well I never did get that part figured out. Any help here would be appreciated. I checked and rechecked the wiring but never got my extension to work. I used a micro SD card adapter to go into the card slot on the MP3 player. I drilled holes in the connectors and soldered wires to run to a New card slot for the exterior of the boombox. Essentially this mod was an extension cable adaptor. I tested the setup. All the connections were wired correctly from the adaptor to the New card slot. But I couldn't get the new card reader to work before final install so I gave up.
My final solution was to hack open a spot in the cassette carriage and deck to get to the MP3 player card slot. Fortunately the Zen is compatible with an 8 gig card. Most MP3 players only allow a 2 gig. Needless to say that 8 gigs lets you store a lot of music.
Unfortunately the Zen I purchased was a refurbished unit. Not long after I started using it I had a miserable time updating firmware or loading anything on the actual MP3 player itself. This means I have to crack the boombox any time I want to add or change music.
comment
Add Comment
jerkey
says:
Add Comment
