Ghost Behind a Door
Published
Introduction: Ghost Behind a Door
Hello everybody, here is an art titled by GHOST BEHIND A DOOR.
.This ghost like face is made by using a nest of bird(hanging type).which we can arrange behind a door. When door is closed the ghost starts blinking its eyes & starts moving too & fro feels as if its calling us.
Parts required are :
1.nest (hanging type)
2.swing motor(which is used in air coolers)
3.LED blinking circuits
4.push switch
5. seasor
6.1/4” pipe
7.hard binding wire
8.A red magic ball (small one, cut into halves)
Step 1: SHAPING THE NEST
Take the hanging type nest from a tree.
1)shape the nest by cropping off the elongated portion at the bottom side of nest(keep about 2 inches as neck)
2) Then shape the eye and mouth as desired shape(using scissor)
Step 2: PAINTING THE NEST
3. Now paint the structure with white paint & black at its head to look attractive.
Step 3: ARRANGING THE EYE BLINKING CIRCUIT
4.Arrange the blinking circuit inside the nest take LED’S out from each eye.Using glue stick each LED inside a magic ball which should be cut into 2 halves & then LED should be stiked in. Power up the circuit with DC 6volt adopter.
Step 4: ARRANGING THE BULB INSIDE MOUTH
5.Now place a bulb inside its mouth then cover with red color plastic. Wrap the plastic like tongue shape & connect the bulb to AC supply along with eye blinking circuitry .
Step 5: ​PLACING THE MODEL AND ARRANGEMENT OF SWINGING MOTOR
6. Place the structure on a support of nail or a hanger.
7. Place the swing motor to a wall using support of nail as shown in the above pic.
8.Then bend the ¼” pipe in ‘Z’ shape & fix one end of
pipe to swing motor using screw.
9.make a loop at one side of the binding wire, fix it into the another end of the ‘Z’ shaped pipe. Then the other of binding wire should be tied to the peak of the nest.this arrangement is shown in above pics.
Step 6: ARRANGEMENT OF SWITCH
10.At last connect a push switch between circuit & power supply. Fix this switch between the space of door.
11.ON the supply, close the door the switch gets closed & there a ghost blinks eyes with motion.....!!!!!
(looks effective during dark with LED focusing at it and arranging fog machine behind it)
Hope u may enjoy doing this stuff, try it..........
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
