Hello Everyone,
First, I would like to thank you for viewing my instructable.
And, if you enjoyed it, please give me a vote!
Thanks....
When Ghostbusters first came out in 1984.
I just got out of the US Army.
My older brother had originally made this costume back in 1984.
26 year ago.
So, today I tried to duplicate what I remember from then.
As, I thought it was a very good costume.
I believe he took 1st place at some costume parties.
The costume is fairly easy to make.
Cheap too.
Costume total cost was under $25.
There are many different ways to do things, so I am showing
you the way I did it.
If you know of a better or cheaper way, let us know.
( I believe, there may be a Ghostbusters III coming out in 2012!)
Now onto the instructable...
If you like my instructable, please take a second and vote for me!
Step 1: Items Needed To Make The Costume
Materials Needed
$10 1 - 2" x 4' x 8' sheet of white foam (at your local home store)
$6 Paint (sample cans at your local home store)
red and White
$4 1 - White Sheet (or take the one off your bed!)
$1 6 - Ceiling hooks
$1 6 - Rubber Bands
$3 Transparency film (or just freehand the drawing!)
Tools Needed
Jig saw
Router
Overhead projector (or freehand draw it)
Paintbrush
3/4 drill bit (for the eye holes)
Epoxy or white glue
Sandpaper (100 grit and 220 grit)
Now, onto transferring the logo to the foam...
Step 2: Transferring The Ghostbuster Logo To The Foam
overhead projector.
That way, I get everything in correct proportions.
Get the Ghostbuster logo above.
I converted the logo to a vector in Coreldraw.
I made a transparency with my laser copier.
Then I projected it onto the foam.
I used a red sharpie to outline the logo.
Now onto the next step...
Step 3: Cutting The Foam
My jigsaw just cuts, above the 2" foam thickness,
which made it very easy to cut.
I just laid the foam flat and cut on the lines.
Then there was only about 1/8" of foam left, where I just snap broke it.
You don't have to be exact as you can sand it, very easy.
Cutting the foam is very messy, I would recommend to cut it outside.
(it sticks to everything from the static)
Step 4: Sand And Smooth Edges
You do want to give the foam contours, where needed.
As, in the hands and top part of the head.
I rounded all edges and corners.
Foam is very easy to sand, but very messy.
Something you want to do outside.
After sanding with the 100 grit, I switched to 220 grit.
That really smoothed it out.
Now onto the next step, routing the eyes, nose and mouth.
Step 5: Router the Eyes and Mouth (or hand carve them!)
I used my router.
I did use a 1/2" half round bit.
The foam routed very easy.
I also routed a depression in the back for your nose.
I used a 3/4 drill bit for the eye holes.
You could also carve them out.
Next, we have to have a way to mount the face on our head.
So, I got some ceiling hooks and epoxied them onto the back of the foam.
Each hand will get 2 hooks and the face will get 2 hooks.
Then, stretch a rubber band across the hooks and you have your hand holds.
Now, some paint....
Step 6: Paint
As the paint will act like a sealer.
First, I primed the foam then painted it.
I used sample paint from my local home store.
Cost about $3 a jar.
Red and White.
For the black I used some acrylic paint.
Now, the costume is ready!
Put the sheet over yourself.
Cut some eye holes in the sheet, or cut a hole in the sheet
and put your head through.
Slip into the "No" sign and put on the mask and hold onto the hands!
Happy Halloween!
Picture is worth a 1000 words!
GOOD LUCK and hope you win some contests!
I hope you enjoyed my instructable!
Oh, his name is "Angus"! lol
Visit Our Store »
Go Pro Today »
GREAT job!
You got it to the "T"!
Glad you enjoyed the instructable!
Make sure and give me a vote!
It was a hit!!
It looks like a wall-mount, I was surprised to realize there's a person underneath. Great job!
When I used to be more of an actor our set guy made most of our large props and backgrounds from sheet styrofoam like that, if I recall correctly his preferred method of cutting/slicing/detailing the foam was by heating a butter knife with a propane torch and then it goes through the foam like magic without leaving a huge mess of white bits. Never tried it myself but after seeing this I just might, thanks!
The "no sign" might break easily. if you glue cardboard or paneling to the back, it'll strengthen it against accidental bumps.
Cartoon gloves.
I was thinking of regular white gloves.
GREAT thought!
I tried white gloves, and it just is not the same.
The hands would be too small, then.
As, for the "no sign" breaking, it is 2 inch thick foam.
It is pretty reliable.
You could break it easy over your knee, but other then that I think it would be fine.
I wanted to keep it lite!
Thanks for the tips, though..
And don't forget to give me a vote!
