loading
Step 3: 3) Disassembly of T215 Device
Step 7: Open your Motorola T215 by removing the sticky pads covering 6 screws. Remove the 6 screws using the fine Phillips screwdriver and carefully crack the housing into an upper and lower half. At this point, also disconnect the li-po battery and place that half of the T215 aside.
Step 8: Remove the red microphone in the T215 from its place by wiggling and prying gently. Take care not to wreck the wiring between the microphone and board.
Step 9: Using the fine Phillips screwdriver, remove the screws holding the long circuit board (button/controls) half of the board in place inside the T215. You will notice that the board for controls and the main board are connected with a fine ribbon cable. Take care not to kink or rip this cable.
Step 10: Mark the surface buttons with their function using the outside of the case buttons for reference, as you will be cutting this part of the housing off later.
Clean and easy to follow. May try to put this together over Christmas break. Great job.
About This Instructable
8,645views
32favorites
License:
Bio: I'm a husband and father of two who enjoys costuming, prop making, and gaming.
More by coryalex:Ghostbusters MT500 Radio with Bluetooth upgrade
Add instructable to:
