loading
Step 3: Sculpting the Parts
Once again we started out by looking at stills and downloading the blueprints we needed from [ GBFans.com]GBFans.com. But the site was also great to find out how most people went about constructing their own packs. We found that most people seemed to cut their parts out of wood and/or vacuum form them. We on the other hand didn't want an all wood pack because of the weight, and vacuum forming was just going to be too complicated and expensive.
So we cut our parts out of insolation foam. This stuff is very dense and very pink. And perfect in terms of weight and ease of use. Jess and I had both used this stuff while at art school (SCAD) and with a little work you can get some great results.
But we also went one step further to really get things smooth and the corners sharp by coating each piece with spackle and then sanding it down. This really is the key to getting a foam pack look like machined parts. It even leaves a very nice and subtle texture that really feels like steel machined parts.
Then by adding a couple pieces of PVC you start to really get down the shapes needed for an authentic Proton Pack.
Again Home Depot was the store of choice.
(These are obviously just a couple of the parts we made, and don't include the battery pack etc.)
<p>Here is a link to my photo album of my proton pack for my five year old inspired by Zombie DUG. Thanks Zombie DUG.</p><p>https://flic.kr/s/aHskMPJcxc</p>
<p>While I did not follow the exact specs off of GBFans, I wanted to post and thank Zombie Dug for helping me put together a great pack for my kid. It was _WAY_ more work than I planned on when I simply told my wife &quot;he wants to be a Ghost Buster? Sure, I'll build the pack&quot; ... I had no idea what to do and Z.D. here gave me all I needed really.</p><p>One key thing from this was actually the wiring of the All-Electronics blinkenlights for the cyclotron. I bought some of the tiny kits off of their site but without the notes on using both a daisy chain AND increasing capacity capacitors, I would not have achieved a reasonable effect. Also the turkey baster for the thrower tip was key. </p><p>I made a couple of minor improvements (perhaps) I'll share.</p><p>1) The baster for the thrower tip is not crystal clear. I think this is key because we don't want to see the LEDs faking the proton effect. Second, the &quot;Frosted&quot; plastic basters tend to really pickup the color from the light and make it visible... like fog and flashlights.</p><p>2) I made the gun modular from the backpack. I used RJ45 connectors on the pack and inside the gun handle, and used a standard-wired ethernet cord (albeit I custom made it to the right length) as the wire between the two. I used cat6 cable that is rated for vertical runs which means it has a plenum inside that gives it extra strength. When I want to store or work on just the pack I can disconnect the thrower from the pack. Likewise, I can unplug the gun from the cable and work on just it. For an active five-year old, being able to remove the potential complication of a thrower and cable from him running around is a bonus, too. The jacks I used are just Home Despot-acquired Leviton cat6 wall jacks ... so they use a mini-punch-down on the back of each jack. This gives you a max of 4 possible circuits that run through the thrower... I used three. Also, I still ran the cat6 cable inside of a ribbed hose (one used for hiding... cables), so it doesn't look like cat6 cable.</p><p>3) Because the pack and thrower are connected by up to four circuits, I stored the 9v batteries (one per circuit, like Z.D. had) in the back pack. I used a hinge on the &quot;battery box&quot; to let me open it up (secured by hidden velcro) for when I inevitably will need to change batteries.</p><p>4) For a five year old, I did not feel the &quot;masonite&quot; (AKA hardboard, aka lots of other names) suggested by Z.D. was sufficient. It feels too weak and certainly too flexible. I used 1/4&quot; basic MDF from Home Despot. It _is_ heavier, but tougher, and ... this is key for those doing a backpack for a small kid... you will have trouble finding a cheap actual pack frame for a small kid. You can try making one from PVC pipes. I just bought olive-drab webbing from Amazon, and plastic clips, and Gorilla-Glued the webbing to the MDF to make the pack. I doubt it would be good for an all-day hike, but for a couple hours of tricking and treating, he can carry it. If I had done this with Masonite, it would have flexed too much and probably broken some of the parts of the pack.</p><p>5) All Electronics is a cool site and I appreciate Z.D. pointing us there. However, I bought their &quot;chaser&quot; circuit kit and feel that the circuit used on my son's pack is far superior... he had already put together the Larson Scanner kit from Evil Mad Scientist. It is a _much_ smoother display that is also more compact. I've been informed that the best way to run the Larson Scanner on a 9v battery is to put 3 regular red LEDs in front of it in the circuit to drop the voltage, because the Larson Scanner kit runs on 3v. So again, for a kid costume that is not movie accurate, more lights is better.</p><p>6) My thrower uses two, not one, of the fast-color changing 10mm RGB LEDs from Spark Fun. As far as. I can tell Z.D. used 1 LED? And I am not sure the intensity. Unlike Z.D. I did not cut my baster-tip short (I wasn't going for 100% movie accurate). The brightness of these LEDs both lights up the sides of the frosted plastic, AND when pointed at a wall in a dark place, makes a clear image on the wall where it is pointing. Not quite laser-pointer, but neat for a kid to feel like he is actually shooting something. I didn't plan this... it was just a bonus find.</p><p>Like Z.D. I am very interested in improving the pack with an Arduino or something that can playback sounds... specifically, I feel like the pack REALLY needs to make the power-on and humming sounds from the movie. It is an unlicensed nuclear accelerator, after all! But time and budget stood in my way... mostly budget.</p><p>Thanks Z.D.! I'll leave a couple of YT vids here of my son showing off the pack.</p><p><a href="https://www.youtube.com/attribution_link?a=SijUo1B6Ut8&u=/watch%3Fv%3DHr9EmhwetSM%26feature%3Dem-upload_owner" rel="nofollow"> Hadrian Ghost Buster #1 </a></p><p><a href="https://www.youtube.com/attribution_link?a=ZkA9n7iWx38&u=/watch%3Fv%3DeD2sHrb4sSI%26feature%3Dem-upload_owner" rel="nofollow"> Hadrian Ghost Buster #2</a><a href="https://www.youtube.com/attribution_link?a=ZkA9n7iWx38&u=/watch%3Fv%3DeD2sHrb4sSI%26feature%3Dem-upload_owner" rel="nofollow"> </a></p>
<p>Thanks for such an awesome comment!!! It made my day to see those videos. I'm really glad that this little instructable helped make an awesome costume for your son this Halloween! He's one great looking Ghostbuster!</p>
<p>What did you use for the externally attached red and blue wires on the pack? And the L connectors they seem to plug into? Those are nice detail. Did you also do any connected tube/wire thing that runs from the left hip in the front to the pack?</p>
I'm trying to build a proton pack using your instructions, and I was wondering if you could think of any more &quot;wallet-friendly&quot; alternatives to the ALICE pack.
<p>I picked up a Molle II frame (only) for $13 off of Amazon. Used but in good condition. It may not be as authentic looking as an ALICE frame at first, but with some decoration, it should be barely noticeable.</p>
You could probably make a similar frame out of PVC fairly cheap and pick up a used backpack at your local goodwill-type store fairly cheap and find a way to attach the straps to the PVC frame, after you have painted the frame of course.
Sorry, not really. That's kind of the one thing that's an absolute necessity for this project. The best thing I could offer would be the check your local Army surplus store though. They might have it for cheaper than what you're finding online. Good luck!
<p>Hi, can you talk about the &quot;metal window siding&quot; you used for the bumper? I can't locate anything like that at my Home Depot, so I might be asking for it by name incorrectly.</p>
<p>I asked about this at HD as well. At first they had no idea but this old dude who had nothing better to do kept wandering around looking. Finally when I thought he had gone for good he showed up with a great thing that looks _similar_ which came from the air duct section... but the goal is thin metal that can be bent. I'd be more interested in knowing now how the OP bent his bumper.</p>
<p>How much would you charge to make one of these for me? </p>
<p>awesome! My girlfriend and I were thinking of being ghost busters this year </p>
It was a big hit!
<p>I'm attempting to build my own based off of this design with a few minor changes, the only major change is that I'm using a raspberry pi to control the lights so I need to know how long does each light in the cyclotron stay on before the next one turns on?</p>
<p>Great Job man!</p>
Would you want to sell it?
<p>what kind of insilation foam did you use? It looks a lot thicker then what I'm finding in my area. </p>
Can you use cardboard instead of masonite board?
dear zombiedug some guy that works for placement says that is his proton pack so can you help me out from beleving him please thank you sincerely cody sucena who ya gonna call?
I'm sorry but your comment wasn't very clear. Who exactly is claiming that my proton pack is theirs? Because it most certainly is NOT.<br><br>Thanks,<br>Doug
dear zombiedug i am also trying to build a proton pack as im just wanting you to know that i am inspierd to build one with your premisson could you please email me the instrutions for me to build one. thank you
humm...i would have never thought of that, good one :)
Quick question, where did you get the ribbon on the cyclotron? Did you just have it laying around? Thanks!
stick a flame thrower on it
i like how you roll
what are the values of the capicitors. My friends and are trying to figure out how you did this.
Which LED kit did you buy? And do you have a video of the lights, battery pack &amp; cyclotron, so we see how yours ended up?
Can you make one for me and send it? PM me ;D
please tell me how big is the pack it self is it 3 feet or what i need to know and the middle is
Once again, please refer to the blueprints that I linked to over at GBFans.com . It's all right there, you just need to read them. Thanks!
how much is the final weight? you seemed to use a lot of wood, and in the ones my club and i have always made have as little wood is possible (mostly pvc - we make one or two wood packs then vacuu-form {did i spell that right?}), and they're still a good 10 or so pounds.
Since most of it is made out of insulation foam, the heaviest part is the motherboard and frame. The motherboard is made out of particleboard, so it's very dense but much lighter than your regular milling woods. In the end the final pack only weighs 5 or so pounds.
what kind of window sliding ?
Just generic plastic window trim
how big is the pack it self is it like 4 feet long im trying to build one to some day as well i love your version of the proton pack so awesome
check out the schematics over on GBFans.com for all scale questions. It's roughly 3 1/2 feet though.
2 years later and I'm still blown away by how much you all like the packs! I'm currently working on a &quot;part 2&quot; to this instructable on how to add arduino controlled lights and sound...and even a rumble pack for the gun! Schematics, code, the works. So keep your eyes open, because I should have it up just after Halloween with pictures and a new demo video!
really cool
that is the best proton pack ever i want one<br>
A proton pack is not a toy.........
Hi, I have to make 30 proton packs for a special needs camp next summer. Can the mold make many wands can it make? Also, do you think they end up sturdy enough for kids to use the whole summer? Thank you.
If you follow the recommendation of the silicon grade I used to make the mold of the gun box, you can easily get 30 made. As for the question about the sturdiness of the packs, that really comes down to how much time and care you put into constructing it. Instead of using a glue gun, you could always use epoxy for example. But you still need to be careful or yes, the packs will break since it's made out of foam predominantly. Good luck on your build! Sounds like it's for a great cause.
Thanks, ZombieDUG! - dramaplay
Were you at the Greenville Parade the year before last in costume? If so the costumes looked great.
Ha, no I was not. But I'm glad to see there are other Ghostbusters keeping the streets safe out there!
This is so brilliant!&nbsp;Wish I&nbsp;had seen this before Halloween.<br />
What types of cans did you use for the N-Filter and HGA.
&nbsp;They were just Pringles cans that we raided from the Dollar Store. There's a ton of great stuff at that store if you do a little digging.
They were both just Pringle's cans we got at the dollar store.
what did you use for the gun mount clip there in the first pic ? i am bulding my pack now and thats kind of a hang up...lol
About This Instructable
306,039views
281favorites
License:
Bio: Nuke Compositor and Lighter working in the VFX industry
More by ZombieDUG:Ghostbusters Proton Pack
Add instructable to:
