Step 4Glue the Wood
Spread a thin layer (don't just slather it on thickly!) of glue on both sides of each sawdust-free (this is important) board and clamp them together. Have a dry run before you glue the wood, put the worst pieces of wood either in the middle or on the outside (middle so it's hidden, outside so that it'll be turned down into sawdust). Put down paper so you won't get glue on your clamps and/or workspace.
Also, all wood is warped, since all of these segments are from the same board they should all bow the same way. Make note of this while clamping, have all of the pieces of wood bow the same way so that there will be a smaller gap in between segments, thus creating a stronger, cleaner joint.
Once the Glue is dry, scrape off as much excess glue as possible; the glue is harder than the wood and will dull your lathe tools faster.
Add Comment
