Step 9Find the Center and Drill
Now we have to find the center so that we can drill 2 holes equidistant to it for the legs of the LED. This is probably not too necessary (because you won't be covering the base in silicone later, unlike me). Instead of following steps 9 and 10 you could just drill a hole in the vague center and insert a dowel rod (to give it support while creating the mold)
To find the center of a circle you need a ruler and a right triangle. Draw a random triangle into the base of the led and find the center of each line. Using the right triangle, draw a line that is the perpendicular bisector of each of the triangle's sides. They should all converge to a central point which is the center of the circumscribed circle, the LED. Geometry class actually helped in a real life situation! Who would have thought?
Now that you have found the center, draw in the diameter. Drill 2 (5/16) holes along the diameter, each 1.5cm away from the center.
comments
Add Comment
Add Comment
