Giant 555 Timer Chip Cardboard Piano Bench
 by caitlinsdad
Featured
or seat, stepstool, endtable, coffee table, poster bed, nightstand, etc.  Just as versatile as it's electronic component integrated circuit counterpart, use cardboard or "card" in the UK, to make this dandy piece of furniture. Besides being appropriate for electronic musicians, this is the geeky thing to have as a conversation piece in the living room, den or hackerspace.  Try your hand first at the Giant Fn Computer Key to get some Fn practice in building with cardboard.  This takes it a another step with engineered cardboard components to give it strength.
I think I might need a giant 20 megawatt soldering iron to solder this in place.
The idea was from seeing this scaled up 555 timer chip footstool.  It was made from lasercut plywood panels and glue laminated together.  1. I do not have a lasercutter. 2. Not the most efficient use of materials, especially cabinet grade plywood to form a chunky solid mass.  So what do we do?  1. Make it bigger. 2. Build it out of cardboard which is plentiful waiting to be recycled.  3. Demonstrate cardboard can be engineered in structures for great strength.
Maybe a giant transistor or LED cardboard barstool is my next project.
Step 1: Basic components...
You need lots of cardboard boxes to use.
Try to salvage the boxes that have a good thick coating paper and don't compress too much or are not squishy.  Thicker heavy duty boxes are more rigid.  Don't try to use cardboard that have a glossy printing or surface on them.  Rip off all packing tape, labels, and just discard the stapled seams.
For this project you need about a quart and a half of glue.
I use carpenter's glue which is tackier and sets up faster than white glue.  It might help to have some spring paper clamps or real clamps to hold some parts where the cardboard wants to flex out and not stick on.  Stapling with a heavy duty stapler seems not to work too well as there is no solid surface for the staples to really bite into.
I also had some white glue to mix with water 50/50 to use for papier mache.
Have a ream of coverstock paper or 50lb weight rated thin cardboard.  I find it better than using old newspapers since it gives a more solid finish and you don't need that many layers to bridge a gap in papier mache.  I use pieces as glue tabs to help the cardboard pieces get clamped in place while the glue sets up.
You will need some material to make the cushion.  Maybe about a yard of fabric in a dark color.  I found this cool techno looking houndstoothy micro-dotted fabric.
I used two old pillows folded in half and stuffed side by side in the seat cushion cover.  You can also get seating foam but that might be expensive for a nice 4 inch thick chunk of foam.
I used a serger to just seam my seat cushion cover.  It is really a big pillowcase.  A simple straight stitch sewing machine would also do the job or take your time and hand sew it.
You will need some black paint, gray paint - or mix it up with back and white paint, and I used some fabric first aid bandage tape to do the lettering on the chip.  Caitlin banned me from raiding her fabric paint stash.
And lastly, have your assortment of cutting tools like utility knives, scissors, shears, etc to cut the cardboard.
CAUTION: Utility knifes and other blades are sharp.  Be aware it can cut through and damage something under the cardboard like yourself.   Do not force it through the material.  Know how to use your sewing machine and serger safely. Know how to paint without making a mess.  And peel off the glue from your fingers every once in a while.
EET1982 says: Aug 7, 2012. 8:40 PM
I want one :)
Adambowker98 says: May 5, 2012. 4:09 PM
Have you thought about putting a real timer inside and connecting all the legs together (your fabric would have to be conductive fabric of course) so that it would really work?
caitlinsdad (author) in reply to Adambowker98May 5, 2012. 9:59 AM
I haven't made a bunch of giant LEDs that I could hook up to it.  Besides, the noise and high resistivity of conductive fabric would not be a good choice for digital circuits.
Adambowker98 in reply to caitlinsdadMay 5, 2012. 5:22 PM
Ah, your probably right. Well maybe after you make some giant LEDs you could maybe just use a strip of aluminum foil or metal on the legs.
roberto111 says: Feb 20, 2012. 10:55 PM
lol ...what s next.....curious....
WorldOfTanks says: Jan 30, 2012. 6:49 PM
you should make a 3909 led flasher lol
-max- says: Jan 29, 2012. 3:22 PM
that would be epic if the legs were medal and were atached to a real 555 inside. then you could connect it up!
Gary Viveiros in reply to -max-Jan 29, 2012. 11:30 PM
You could do that if you made others out of CMOS logic gates, because the capacitive coupling could do binary counting when certain people hold hands, on other logic elements, with the 555 acting as the master clock. ha ha - gotta love ths one! Makes you wonder why no one thought of it before...
jwoo2023 in reply to -max-Jan 29, 2012. 9:30 PM
good idea!, and make other giant components and make a circuit!
caitlinsdad (author) in reply to jwoo2023Jan 29, 2012. 9:55 PM
Some work and components on  aTINY breadboard.
Taerzik says: Jan 29, 2012. 10:14 PM
Awesome. nuff said
harari says: Jan 29, 2012. 6:27 AM
Very cool!
now the next step would be a breadboard floor and a 24DIP IC for the bed. maybe some giant LEDs for lighting and an electrolytic capacitor for a night stand...
caitlinsdad (author) in reply to harariJan 29, 2012. 9:49 PM
But you would have to keep your room clean otherwise there would be shorts on the floor.
Kiteman says: Jan 27, 2012. 11:13 AM
So, now you need the fully-functional cardboard piano to sit at.
Or possibly a giant Stylophone...
caitlinsdad (author) in reply to KitemanJan 27, 2012. 1:51 PM
I will need to make a Bosendorfer Imperial then.
omalachowski in reply to caitlinsdadJan 29, 2012. 11:05 AM
I heartily endorse this idea and look forward to the instructable.
jgrecoarroyo says: Jan 29, 2012. 7:15 AM
Very geeky, I love it!
Robot Lover says: Jan 28, 2012. 2:51 PM
I would totally make one of these! Although, I would make mine outta wood. Kinda like this one: http://www.evilmadscientist.com/article.php/555stool
caitlinsdad (author) in reply to Robot LoverJan 28, 2012. 4:41 PM
It would be easier to make it out of wood but the point is, you can make it out of cardboard and suited for stealth projects in the dorm room where you can't lug up sheets of plywood and timber and be hammering, sawing or screwing away all night....wait
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
