Giant Ant Geocache
1,632
33
9
Posted
Introduction: Giant Ant Geocache
Materials:
  • Balloons x 3
  • Plastic bags x 3
  • Masking tape
  • Expanding foam
  • Pantyhose
  • Irrigation tubing
  • Irrigation joins - right angle x 18, cross x 1, T-shape x 2
  • Glow stick x 2
  • Ping pong ball x 1
  • Cable ties x 4
  • Used medicine container x 1
  • PVC pipe x 1
  • PVC cement
  • Paint - brown/black
  • Cloth
  • Rubber bands
Step 1: Building the Body
This actually started as my attempt to make 'Duct Tape Batman Mask' by seamster. As I was making it by myself, I wrapped the tape around a balloon, not my head. This then gave me the idea of creating a giant ant!
To start I blew up one balloon and then placed it in a plastic bag, then wrapped the whole thing in masking tape. I placed it in a bag so when I popped the balloon it didn't cause the whole thing to collapse. If you wrap it in many layers it becomes very strong.
I made three balls this way, blowing up the balloons to the sizes I wanted. For the ball I wanted to use as a head, I cut a ping pong ball in half and taped the two sides down as eyes.
The next step was the hardest. To connect the three balls together I cut holes in the outside balls and two holes in the middle ball. As I wanted to make it into a geocache I also cut a hole in the top of the middle ball to hold a medicine container. The container could be anything. I then cut a piece of PVC pipe to act as the the spine and fed it through the three balls. I the taped the whole thing together.
For added strength I then cut a small hole in each ball and filled them up with expanding foam. This then took about a week for the foam to dry. When it was dry the body was very strong but light. I then covered it in pantyhose and used rubber bands to make sure the pantyhose conformed to the body.
Step 2: Adding Feelers / Painting the Body
Next I painted the body with PVC cement, this hardens up the pantyhose and protects it for outside use. Then I added feelers. For the feelers I used two long skinny glow sticks. I drilled two small holes in the head, and pushed the glow sticks into the holes. I glued them in place using the PVC cement. I then spray painted the body brown and used some black paint to colour the eyes.
Step 3: Adding Legs
I made the legs using irrigation tubing. I bought I strip of black tube and then cut it to shape. I made it so it would cradle the body to make attaching the legs easier. I used 1 x cross join and 2 x T-joins for the spine and then 3 x right angle joins for each leg. For added strength I wrapped each join in cloth and painted it with PVC cement.
I kept the legs black, but spray painted the joins brown. To attach it to the body I painted two cable ties brown, and then used them to attach the legs to the body. This proved very sturdy. I also used a knife to cut around the cap of the medicine container so it could be opened.
Step 4: Finished Geocache
Now the geocache was ready to be placed into the wild. I placed a log sheet into the medicine container and found a secluded spot in the bush to hide the cache. I used a couple more cable ties placed between the spine of the legs, and the body to attache the cache to a tree. I was very happy with the final result, much better than a batman mask.
  • Minecraft Challenge 2018
  • Sew Warm Contest 2018
  • Gluten Free Challenge
9 Comments
This would be fun for a metro park to create a nature themed series of these and place them in all of their facilities.
I love your caches. I wish they were closer to the West Coast so I could see them in person.
Thanks, most of these are part of a trail I'm currently working on. I'll post some more instructables soon.
Make a few hundred of these and you can film your own horror movie. Thumbs Up!
they should rename it to giANT geocache
Ha, I called the listing 'Empire of the Ant', but I like that a lot, it's not published yet so I might just change the name ;)
If the logsheet and souvenirs can't be hidden inside, I have doubts about it being a geocache.
It has enough room for a logsheet, there's about the same room you would get in a bison tube micro. But you are correct, there is no room for swaps.
Not all geocaches have SWAG, some just a log. It's still a pretty cool cache!
