Introduction: Giant Cordless Power Drill - Prop
When you have a tool, size matters. Here's how to build a giant cordless power drill.
This will be used as a prop for Caitlin's contractor/builder Halloween costume for this year (easy- hardhat/googles, toolbelt, and usual schoolclothes). Yes, she knows how to handle power tools safely. And with pic of her in costume from her school parade.
This instructable shows you that you can pretty much imagine anything and build it giant-sized for a kid. In additon to making swell props for your Halloween costume, these have potential utility for children to use in their classroom or for class plays.
So to add to our list of giant Twinkies, giant magnet and giant toothbrush, here is our giant cordless power drill instructable.
Step 1: Useless Stuff to Useful Stuff
This prop was made from stuff laying around the house. As usual, a trip to the recycling bin to find some materials to reuse.
You will need:
- some cardboard
- some plastic bottles in various shapes
- a piece of wood to use as a handle 1"x3" pine
- a wood dowel 3/8" diameter
- handheld fan
- a momentary push switch and wire to mod the handheld fan
- for decoration, various colors of duct tape, electrical tape, clear packaging tape
- aluminum duct tape, this stuff is great for adding the look of metal to any object.
- some screws for attaching parts
- some printed images of logos or warning labels to add realism to your project.
- basic tools to cut wood, cardboard and plastic
CAUTION: Scissors and utility knives are sharp. Know how to handle and properly use them safely. Cut plastic will leave sharp edges. Put tape over the cut edges for safety.
Step 2: Visualize Your Design
Gather up parts that resemble parts of the cordless drill that we are going to make.
It helps to have a real cordless drill or picture of one to use as your model for the project.
I had a nice large juice container that was perfect for the body of the drill.
A vitamin bottle was perfect to add on the front as the keyless chuck.
I had to make the handle from a scrap piece of wood.
I had to make the "battery pack" from scratch.
Step 3: Mish Mash
The vitamin bottle would do great as the chuck of the cordless drill.
Cut the bottom of the vitamin bottle to fit the cap of the larger juice bottle. The size of the hole also allowed me to push the vitamin bottle further down over a lip of the juice bottle.
The lip locked the vitamin bottle in place and allowed it to spin freely. I was hoping to use this design feature to mechanize the drill bit turning freely powered by something in the main body.
Step 4: Drill Bit
Drill holes through the caps of the vitamin bottle and the large juice bottle to fit the diameter or your dowel.
Use polyurethane glue to glue the juice bottle cap to the hole in the bottom of the vitamin bottle.
Glue in the length of dowel that you will use as your "drill bit".
Eyeball the length of the drill bit so it is in proportion to your drill.
Round off the end of the dowel.
Use narrow strips of cardboard to wind around and glue to the dowel to simulate the twist of the drill bit. Bend the cardboard and shape your spiral so it makes it easier to glue.
Cover with aluminum tape for all the exposed metal-looking parts and use black duct tape for the rubber grip.
I glued the chuck permanently to the body when I found the fan motor was too underpowered to spin the drill bit assembly.
Step 5: Charge It Up...
Build the battery pack.
I had a chunk of styrofoam from the packaging of something that had a good blocky shape to use. Don't worry about gaps or odd shapes. It is easily shaped with a knife, rasp, file, or sandpaper.
Cut out a slot to fit the bottom of the handle.
Adjust the length of your handle and sketch out a handle curve in the wood to cut and shape later.
The battery pack will be skinned over with cardboard to give it its final shape. Just cut out cardboard to shape. You can cover each surface with a many smaller pieces of cardboard.
Laminate about three layers of cardboard with alternating directions of grain to give it strength.
Glue in a platform for the bottom of the handle. It will be also screwed in at that point.
Build up a box shape around the gaps if you have any over the styrofoam.
I also covered raw edges with a layer of cardboard that had been peeled from scrap pieces. It helps with getting a smooth edge when you cover it all with tape.
Step 6: Make It Spin...
Cut an H-shaped or I-shaped slit in the juice bottle used as the main body of the cordless drill.
Slip in the handle to see how it will fit together.
Draw a line to indicate the horizontal axis of your drill bit when the wood handle is centered and pushing on the top of the bottle.
I had one of these dollar-store summer breeze handheld fans laying around the house, I decided to use this to animate the drill by spinning the drill bit. It was a complete self-contained motor in a mount, battery compartment and switch.
I first separated the battery compartment from the fan mount. A quick slice with the hacksaw cut the pivoting studs on the plastic mounting arm so it could to slide over the 1"x3".
I cut a notch in the wood to fit the fan head squarely. The mount was screwed in at the bottom with a touch of polyurethane glue. It foams up a bit to fill gaps and fixed the motor head in place.
I then screwed and glued the battery compartment in place.
CAUTION: Polyurethane glue sticks to everything and is very hard to remove. You can wear gloves when working with it. Always work over newspaper or something disposable to catch the drips.
Needless to say, these fans are nothing more than cheap toys and don't have enough power to move a wooden dowel as I found out. I should have ripped out the drivetrain of a cheap R/C car to use for this. So plan B was to just leave the mechanical guts in and when you pressed the switch, the fan would give it a cool noise that the drill makes.
The last pic shows a reinforcing screw in the fan propeller that I was going to glue into the end of the dowel to drive it but it is obsolete.
I drilled a hole in the handle to friction fit the barrel of the momentary switch I would be adding.
Solder extention wires to the momentary switch. Solder into the circuit of the mounted fan. I cut one of the leads to the battery terminal and patched in my switch with another lead from the motor. Test to see if everything works.
Wrap the handle with electrical tape.
Step 7: NASCARize It
Assemble everything. Insert the fan/switch handle assembly into the slot of the large juice bottle. Center it inside and attach with two screws with washers to the wood handle. Cover any exposed plastic and joints with tape.
Duct tape and aluminum tape can be stretched a bit to conform to the odd shapes. Cut a slit if you need to prevent the bunching up in corners and just tape over itself.
Pick your favorite tool manufacturer's colors to use when you pick the colors for the duct tape.
You can replicate a color scheme exactly and match parts that are the same color as the real cordless drill.
Instead of using any paint for this project, the entire drill is covered in various tapes. No need to wait for the paint to dry and if you miss a spot, just cover it up with more tape.
Print out logos that you want to use to add realism to the product.
Print out battery voltage and warning labels. Cover with clear packaging tape to apply the printed matter to the cordless drill.
So go and make something ~~big~~ Gigantic!
Second Prize in the
DIY Halloween Contest
