Giant Gummi Sculptures by brawns214
Featured
Small gummi bears are great, but for that extra special party snack make a ginormous sized gummi creation. I call mine the Gooey Duck. Essentially the strategy is to buy many pounds of cheap gummi bears and melt them into a mold of some sort (i used a cake mold) and then cool in refrigerator or freezer.
If you search online for World's Largest Gummi Bear, you get a link to Vat19.com offering a measly 1/2 lb gummi and their 'World's Largest' at 5 lbs. They also claim "there is no candy more magnificent or more powerful". Well unfortunately for them I made an even bigger gummi sculpture (at 6lbs though not a bear) 7 years ago!
Gummi=Gummy. Haribo calls them Gold Bears. Black forest calls them Gummy Bears. Whichever you prefer. Original German was gummibär, so that probably originated the gummi bears.
I did this experiment in my youth. So don't blame the current me for the brash and questionable nature of this idea. You've been warned!
Step 1: Procure Gummis and cake mold
6lb bags of Brach's Gummi bears used to be available from costco. I can't confirm anymore whether this is the case, but let's admit it Amazon is probably the best place to go. A brief cursory search revealed:
The cheapest 5lb or 6lb bag was from Brach's at 6lbs for $11.50.
http://amzn.to/cBsPCg
The lowest $/lb ratio for gummi bears was from Albanese at $1.70/lb (10lb for $17) :
http://amzn.to/aPgICd
And going for only top quality from Haribo reveals this gem of a deal 12 lbs for $34.
This should provide plenty. For the Brach's there were 5 colors and for the Haribo and Albanese there appear to many more. So if you want a solid colored gummi monster look for places where you can either buy a bunch of one color or you'll have to buy many many pounds of this stuff.
How I came into 6 lbs of gummi bears was a funny story. After finding they sold such a delightful item at costco, I off-handedly mentioned they should be the token prize at a prize raffle for our highschool band end-of-the-year party. Because of my fortunate luck, I actually won said raffle.
Be creative when choosing a mold. I just got a cheap cake mold from the 99¢ store or something like that. I wanted to do both sides, but it turns out that would've required twice as much and I didn't want liquid gummi seeping through the seems of the mold.
Step 2: Separate gummi bears
If you want the color not to come out solid brown, separate the colors. Eat any mutant gummi bears in your bag. They own't be mutant formed once they are melted.
For me, I wanted a full-sized gummi creation, so I just separated in order to add them in separately once melted. It created a rainbow effect.
Also you're serving this, please use a much more sanitary location than what I chose. Yes I know your heating these up, but just have some self-respect man.
Step 3: Melt Gummy Bears
Without too many problems, you can just melt them in a pot over the stove until they are the consistency of syrup and the bears lose any actual shape. If you're worried about burning them, try a medium heat.
The devil about this step concerns heat. Melted gummi bears are extremely burny and extremely sticky. This is a combination for disaster. If you happen to get some on your skin, you can't wipe it off without smearing over more skin and burning more area. Running it under water of course will cool it down, but you might have burns. Therefore, don't let any animals or little kids get near this. If you're very worried about it, wear oven mits when holding the pot.
Step 4: Line mold and pour
If your mold is silicone, don't worry about it sticking. It should be alright. However, if your mold is metal, it probably will work out if you spray it with non-stick vegetable spray, butter or WD-40 (ok, not the WD-40).
Depending on the color effect you want, mixed, separated or something else pour the colors at the same time and mix them with a utensil (don't touch the melted gummi!). Or if you're limited on pots and don't care about interesting effects you can heat up a pot and pour, then go to the next color. This gives a rainbow effect of whatever colors you have.
If you actually do this instructable, I want to see pictures of the finished creations. I have no doubt this community will able to come up with tantalizing better ideas than Vat19's single color bears.
Step 5: Refrigerate (or freeze) and serve when cool
Cool down your creation in the fridge or freezer or arctic tundra, whichever is more convenient. I can't imagine that correct solidification of gummi requires any difficult processes like tempering or quenching. If you want to experiment with different crystalline structures please inform the community of your results!
When you serve this beast, it will need a knife to cut. Slice it into 1/4" pieces or so and it should be easy enough to chew from there. A single ounce of gummi contains roughly 100 calories, which means there are approximately 10,000 calories for a 6lb gummy monstrosity. So this is a calorie dense snack. Don't let your little brother run off with this thing or he'll be hyper for weeks!
Step 6: Gummy Bear Links
As it stands right now, the world's largest gummi bear for sale (my Gooey Duck was bigger).
http://www.vat19.com/dvds/worlds-largest-gummy-bear.cfm
Update: ARRRGGGH Vat19 touts the World's Largest Gummy Worm at 3lbs! They aren't even trying!!
http://www.vat19.com/dvds/worlds-largest-gummy-worm.cfm
The obligatory wikipedia article
http://en.wikipedia.org/wiki/Gummi_bear
Middle of the page, this guy made sculptures out of individual gummi bears
http://www.yayachou.com/sculpture.htm
The gummibär song. Definitely listen to the german version, but there is also an english version.
http://www.gummibar.de/
1-40 of 41Next »
Cpt. Wolf says: Jul 16, 2012. 4:34 PM
Tried this and failed miserably, several times. Melting was not a problem. The first time, I didn't do anything with the molds. Second time, I dusted them with corn starch. Both times they were impossible to get out.
I What I've learned is that you just can't use plastic chocolate molds. Not small ones anyway. Next time, I'll find silicone molds. Unfortunately, I was doing these for a camping trip this weekend. Guess it'll have to be chocolate instead.
Already, planning space invader ones next time I try though!
brawns214 (author) says: Jul 16, 2012. 5:09 PM
Sorry you had trouble. Do you have internet links to the types of molds you used so others can learn from your troubles?
Cpt. Wolf says: Jul 16, 2012. 8:18 PM
They were just your standard chocolate molds. I got them from http://www.confectioneryhouse.com. I think a couple things might have happened.
1. I sprayed the pot I was using. I think the oil changed the consistency just enough to keep it from totally setting. Didn't make much difference for the pot, it stuck to the pot anyway...
2. The molds I was using were on the smaller side.
3. They had smaller, rougher textures to the designs. So the gummy probably stuck into that a bit more. The plastic is probably porous too, making them stick worse.
Definitely stick with silicone or rubber, something non-porous or stretchy enough that you can freeze the gummy, then you can peel the mold off of it if you need to.
I tested this with cheap dollar store gummy bears and peach rings.  Both melted very easily and at a very low temp.  The cost was considerably cheaper too, you can get a 9oz bag of gummy bears for $1 at most Dollar Trees.  So that's a little over 5.6 lbs for $10.  Really cost effective if you've got a dollar store nearby.
obesemidget says: Dec 23, 2011. 7:24 AM
How can you make your gummy candies not sticky when cooled?? :-/ Mine are sticky :(
Mythbuster009 says: May 13, 2012. 2:30 PM
Before you add the melted gummy bears, put some vegetable oil in the mold and shake or just make sure the inside is covered. This will help with the stickiness of the product and will thereby also make getting the gummy out of the mold since it won't stick to the sides.
Or, you could coat it in corn starch. I don't personally like the color the corn starch gives it, but it's a better anti-stick agent since it's dry. The oil makes it a bit slippery, but you keep the color of the gummy better.
shinyegg says: Sep 19, 2010. 8:01 AM
We made 2 12 pound giant gummi bears.
brawns214 (author) says: Sep 19, 2010. 10:39 AM
Pictures! Or it didn't happen :)
shinyegg says: Sep 25, 2010. 7:19 AM
aidanjarosgrilli says: Mar 17, 2012. 9:30 PM
put it in a bucket of water for a couple of weeks to make it grow to about twice the size.
brawns214 (author) says: Sep 25, 2010. 11:23 AM
Also, is that a custom mold?
shinyegg says: Sep 26, 2010. 4:24 AM
We actually used a container that held animal crackers. It just looked like a giant gummi bear.
craig3 says: Jan 17, 2011. 7:38 AM
How did you get it out?
shinyegg says: Jan 17, 2011. 11:51 AM
I think we cracked it open w/ scissors and any other sharp objects that were lying around.
brawns214 (author) says: Sep 25, 2010. 11:21 AM
Brilliant! Way to blow away the laughably underachieving named 'world's largest gummy bear'!
maximus276 says: Feb 4, 2012. 6:18 PM
actually the largest is 26lbs. and has a hollow stomach
truovrld says: Oct 9, 2011. 12:23 PM
How long would this last? I want to make one for a Halloween party, but would need to make it a week or two ahead of time.
brawns214 (author) says: Oct 9, 2011. 2:41 PM
If you put this in a freezer bag and store it in the refrigerator, you should be fine.
truovrld says: Oct 11, 2011. 7:40 AM
Yay! Giant gummy brain!
xProShotx says: Apr 14, 2011. 6:11 AM
can you do this for small molds like skulls?
brawns214 (author) says: Oct 9, 2011. 2:40 PM
Any mold should do, as long as you can remove it.
bobandthemonkey says: Dec 27, 2010. 9:06 PM
made a large pill sort of thing with this, thanks for the great ible
NatNoBrains says: Dec 16, 2010. 8:25 AM
OMG I'm sooooo doing this!
nijireiki says: Sep 5, 2010. 4:32 AM
You could also use the recipe from SFHandyman's Ible to make a custom giant gummi! (Handy for the diabetics/low-carbers among us.)
willrandship says: Sep 6, 2010. 3:53 PM
That's just jell-o there. really thick finger jello, nothing more. Gummies have mostly corn starch, and not as much gelatin as jell-o
willrandship says: Sep 6, 2010. 3:52 PM
Heck, at my local grocer they have huge bins where you just shovel out the gummies. You can buy them at $2.79/lb or about $8.50 for a 5-lb bag. (not a calculation, they sell 5 lb bags prepacked) The gummies with the foam cost more, but you wouldn't use them for this anyways.
Troyboyd says: Sep 6, 2010. 9:35 AM
the artic tundra xD
Troyboyd says: Sep 6, 2010. 9:33 AM
wd-40 made me lol
margime50 says: Sep 6, 2010. 4:44 AM
This is such a great idea. I have MANY cake and cookie molds and plan on giving it a shot for halloween - hand out gummy pops that are much less expensive than store bought. Thank you for a great way to spend otherwise wasted time :)
Fiction says: Sep 5, 2010. 3:50 PM
Nice! A couple of kids I knew did this in highschool. To keep it in a bear shape, they used a giant bear container that some store like costco sold masses of gummi bears or animal crackers in.
hondaman900 says: Sep 5, 2010. 9:43 AM
If you float the bowl of gummis in another pot of water, and boiled the water, would that be hot enough (100c) to melt the gummis? It's a method used to melt other things like chocolate or wax without burning them. As long as there's still water in the main pot the temp will not exceed 100c.
brawns214 (author) says: Sep 5, 2010. 11:52 AM
I think I remember trying double boiling and it was just way too slow. Though that was many years ago, my memory may not be so good. Worth another attempt perhaps
brawns214 (author) says: Sep 5, 2010. 7:32 AM
Did you line the pan with something like vegetable spray? I remember that helping.
piaferre says: Sep 5, 2010. 7:11 AM
I'll sooo do this for my next bday
Trebor__24 says: Sep 5, 2010. 4:26 AM
it keeps sticking to the mold :( im sad
thepelton says: Sep 4, 2010. 3:11 PM
I thought the largest bivalve was the Tridacna gigas.
INSTRUCTUBAL says: Sep 4, 2010. 12:20 AM
This, is AWESOME.
xilefakamot says: Sep 3, 2010. 1:42 PM
If you're lazy you can get giant Gummi Bears here
Still, great i'ble - I might have to try this!
brawns214 (author) says: Sep 3, 2010. 7:34 PM
Well unfortunately, this is only the 5 lb gummi bear that you'll find everywhere else. But who is lazy on instructables?
bettyz24 says: Sep 3, 2010. 1:28 PM
I love that you did this at your computer desk, vs. a table/in the kitchen. LOL
dark sponge says: Sep 3, 2010. 6:00 PM
USB gummy bear melter...
1-40 of 41Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
