3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Giant "wooden block stacking game" tower
Giant \"wooden block stacking game\" tower
A few months ago I wanted to make an original present for my dad's birthday. I started looking on the internet but nothing seemed to be the kind of thing that I was looking for....  Then the idea struck me. Why not make my own "wooden block stacking " game? Just a little bigger and  suitable for playing outdoors. I had seen it at a friends garden party but when I looked it up afterwards it was quite expensive. So why not make it myself?!
Step 1How to make a "wooden block stacking game"
How to make a \"wooden block stacking game\"
On Wikipedia it says:
"...... is played with 54 wooden blocks. Each block is three times as long as it is wide, and one fifth as thick as it is long (1.5 x 2.5 x 7.5 cm). To set up the game, the included loading tray is used to stack the initial tower which has 18 levels of three blocks placed adjacent to each other along their long side and perpendicular to the previous level (so, for example, if the blocks in the first level lie lengthwise north-south, the second level blocks will lie east-west)"
http://en.wikipedia.org/wiki/Jenga
Materials
* Wooden beams, I used 4 beams of 4m
                                                         (13 feet and 1.48 inches)
*Measuring tools
*hand / table saw
*Pencil
*Sanding paper
                   (8.27 inches)    (2.64 inches)      (1.65 inches)
My blocks are 21cm long, 6.7cm wide and 4.2cm high. I know the 1 to 3 ratio is not applied but I just took some wooden beams that were available at the store and then kind of tried to fit all the pieces in the length of the beams.
When you have all the materials you can start measuring and marking where you are going to saw.
After you have done that you can start to saw!! As finishing touch you can sand down the edges for a smooth look.
Cost : Wooden beams  +/- 25eur , Box 10eur
                                      (36 dollars)        (14 dollars)
Some math:
Y= Length
X= Width
h= Height
Z= number of blocks
X= Y/3
h=Y/5
Total height = Z/3 * h
33 comments
Jul 10, 2011. 8:36 AMmmmatt says:
Hey, thanks for posting this up. Looking this all over this seems very simple, and it is. All you really need to know if in usa and using regular 2x4 wall studs. cut 54 of those suckers at 10.5 inches and you are good to go! THAT being said, I spent less than an hour cutting and a good 12-15 hours finishing. They came out beautiful and are smooth like glass for easy play and good protection. Here is what I learned along the way:
1. Wood selection: Straight isn't that big of a deal... a little bend in an 8' board isn't noticeable when you cut it into 10" chunks. Look for wood that has square edges and minimal or only small knots. Sometimes you get a little colored sap wood and that looks good after finishing. With "spf" 2x4's these blocks are heavy enough, so I would not recommend a hardwood for safety and convenience reasons. If you could find an "s4s"(sanded 4 sides) pine 2x4 that would help with finishing work but it is not likely you will. Select 2x4's are likely only straighter with less knots and select doesn't imply a finish sanded product. I like that my peices had a little character and I had to chuck a couple where the knots were to extreem. You can do it with 7 @ 8' 2x4's but you should get 8 so that you can pick the best pieces.
2. Cutting: Make a jig for your saw. Something that you can but the uncut wood up to so that you cut exactly the same size piece each time. For me this was simply a block of wood screwed to a 1x2 and clamped to my mitre saw. Different jigs for different saws, but I'm sure you get the point.
3. Sanding: I started using 80 grit on a palm sander to knock down all the larger imperfections. There are lots of them too! It took a very long time and I rounded over all the edges. A router would be overkill if you are sanding anyways since it is so easy to cut through pine with sandpaper.. A bench mounted belt sander would have cut a good couple hours off this step but there is still some handwork regardless..
After the 80 on the palm sander I went to 220 grit on a rubber sanding block. Don't forget the end grain! Even if you can't nock it down to perfectly smooth it is still important to open the fibers so the finish penetrates. This went much faster and brought each piece up to glass like smoothness. All and all I spend a good 10-12 hours sanding... I kid you not, and I was busing my hump!
3. Finishing: I used a past finishing wax. I used the Minwax brand that you can get at any hardware or home improvement store. It is a wax in mineral spirits so that it can penetrate the wood fibers a bit. T apply, it is just like waxing your car. Wipe down each piece to get all the dust off, apply a thin layer, let it dry for 30 minutes or so, and then buff it to a shine. They look beautiful with a nice satiny finish, and they have perfect tension during play. They should last a long time too because the wax wont chip or flake off as they get nicked up during use and they are waterproofed short of an extended float in the pool. The wax is also a time release of sorts for letting wood acclimate itself to changes in humidity and will be less likely to warp over time. Yeah, I like wax!
Feb 25, 2012. 12:35 AMXOIIO says:
I would think 2x2s would work better, for something scaled down a bit from this. I want to make one with 6x6's XD
Feb 25, 2012. 9:14 AMmmmatt says:
2x2's and 6x6's are not the proper dimensions but to make the game work you could use whatever as long as the length = 3x width of the pieces so they stack properly. The ratio of dimensions of the original game is not the same as a 2x4 either, but I don't think square stock is a good choice.. Closest to the original is probably a 2x3 if you can find them.
As for 6x6 that is not smart. During play, these come crashing down and even the 2x4's could easily take out an ankle. Also the height of the 2x4 game during play is quite tall. I think the record on my fiends game is about 32 levels and that is over your head when stacking the game only a foot or two off the ground.
As another side note, don't play this on a wooden picnic table or wooden bench because the tower coming down will dent the hell out of your furniture. We have been using a 12x12 concrete landscaping stone on top of a 5 gallon bucket and that works pretty well. Just level out the bucket Concrete floor works well too but it is best to not have to squat down for the lowest pieces.
Feb 21, 2012. 12:53 PMcpowelson says:
with the directions you posted about .. is the game as big as the ong in the orginal pictures of this post?
Feb 21, 2012. 3:41 PMmmmatt says:
yup. US dimensional lumber is only slightly different than the euro stuff. If you have seen a giant jenga I can almost promise that it was made from SPF 2x4 lumber.
As a side note, the wax finish works awesome. Also the weight of the falling blocks is enough to damage a wooden picnic table or a persons foot so use with care.
Feb 21, 2012. 12:51 PMcpowelson says:
So to bulid the one that is in the pictures of the steps... just get 2x4's, make 72 blocks or 54?
Feb 7, 2012. 11:33 AMMPYOUNG33 says:
I found it less expensive to buy this game already made. To make it I would have had to buy lumber, a saw, and sander which would've been $100-$150. The least expensive place I could find to buy this game was Ebay and Etsy. If you search Giant Huge Jenga it will show up. I think it was $50-$55. We love playing this game at tailgate parties and we add drinking rules to each block to make the game more exciting for adults.
Sep 1, 2011. 6:04 PMgblocks says:
You can also buy sets at GonzoBlocks.com I am in the Sf Bay area so if you want to pick them up you can save on shipping. I have them in bars and now companies are buying them for "team building"
Jul 28, 2011. 11:29 AMttowers says:
Yeah great idea... making your own original gift is always a great idea :) If you want for a great price though and rather not spend the time or have the tools. www.TumblingTowers.com is great. They have free ground shipping on all sets and they start at 76 or 96 for the giant one. Awesome gift and plenty of party use :)
Jul 13, 2011. 5:06 PMbajablue says:
This was a GREAT project! Congrats!!!
Jul 10, 2011. 11:08 AMmmmatt says:
Also wanted to note that a rubbermaid or steralite container in the 75-80 litre size is perfect for storing these. I ended up buying a 57 litre container first and it was too small by about 10 pieces. Also the taller more square-ish containers are better than the real wide ones for moving it around. Even with just pine the set is easily 50+ lbs
Jul 3, 2011. 6:44 AMdolabil66 says:
Nice Job......that would be great for a party
Jun 25, 2011. 11:15 AMGreasetattoo says:
Here is mine!!!
Used a 2" x 4".
Just make sure and find straight ones.
Make sure they are dry...
I routed the edges too!
10 1/2" long
54 boards.
I made a stencil and painted the logo on.
Very fun to play...GREAT party game!
Enjoy....
Jun 27, 2011. 2:49 PMcloudifornia says:
Most excellent!
Jun 28, 2011. 1:12 PM5STARGBLOOD says:
im gunna use a 4x4 it might make it easier
Jun 23, 2011. 1:27 PMlberger1 says:
This is great, but you have to remember that lumber is not always perfectly straight or flat. It looks like your standard 2 x 4 in this instructable which are really 1 3/4" x 3 3/4" finished. To make a really well made game you would want to run the lumber through a wood planer. This would obviously shave the face of the lumber and change the dimensions again, so the overall dimensions would shift. It would be really cool if someone expanded on this by using a planer and both metric and standard measurements.
Jun 24, 2011. 12:50 PMRob O says:
that is a good point. the quality of lumber would make a difference. if you used the cheapest 2x4s from a box store this could be a big pain in the neck.
if you got high quality dimensional lumber from an actual lumber store or woodworking store or specialty store you might wind up with a better result.
Jun 24, 2011. 7:27 AMbonnie13 says:
Clever idea for a lawn game. Excellent and detailed instructions. The design is taken from a commercial game. Workmanship is well done, but lacks creativity, intricacy and level of work of some of the other entries.
Jun 23, 2011. 1:38 PMTommy Jae says:
My friend made one of these.
His sister wanted it for her party so he and his dad went out and got the wood (which she paid for) the they did all the work.
Their's was a bit better though 'cause they rounded out the edges so that it slid better.
While the regular Jenga doesn't have rounded edges, it definitely helped with the larger version.
His was about five and a half feet tall.
But all in all,.this instructable is pretty great. I didn't think other people would think to make one of those. Haha.
Jun 23, 2011. 1:14 PMlucek says:
Dread anyone?
Jun 23, 2011. 10:04 AMRob O says:
Brilliant!! I'm going to go home tonight and make my own. I have some sticks of 2x3 that I might play around with too. Either way, what a cool ible. You got my vote in the contest. Thanks much for posting your idea!!
Jun 23, 2011. 9:39 AMcloudifornia says:
This is GREAT!
Jun 23, 2011. 6:54 AMsplazem says:
Awesome!
Jun 23, 2011. 6:22 AMgregr says:
If you measure carefully you'll discover that Jenga blocks are two slighty different thicknesses.
Jun 22, 2011. 4:14 PMdepotdevoid says:
Oh my god, that is awesome! 5 stars and a vote when the contest opens!
Jun 22, 2011. 8:39 PMaggrav8d says:
Now this requires a giant wooden jenga pistol.
http://www.youtube.com/watch?v=F9BmTmMEOhQ
Jun 21, 2011. 3:22 PMchucky987 says:
Very cool. This is a popular bar game in Chicago and it makes for some great times. I had the urge to make this myself (and also for my dad back in NY). I didn't scale up the blocks from the official game, but I thought this worked out ok.
http://www.charlievolanakis.com/post/2548388082/jenga
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Mtoashirbab
