3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Giant Mask: Horror Head!
This Instructable (which will begin by bordering dangerously on "slideshow" and for that, I apologize) is the focal point for my 2008 Halloween costume. A huge, papier-mache mask of gruesome proportions!
And don't forget to vote for Horror Head in the DIY Halloween contest!
Step 1Can You Draw Me?
Can You Draw Me?
Unfortunately, I started this year's Halloween mask shortly before I started using the Instructables website, so I did not bother to take any pictures of the very early stages of construction. I had already done a fairly close coverage of this process on a previous mask project and since the principle is exactly the same, it didn't seem necessary.
In this case, rather than making a papier-mache shell over an inflated punch-ball balloon, I built the mask on a Diamond Comics corrugated cardboard shipping box - this takes far less time and works just as well, but it must be said that this method is slightly less cool.
Besides, even if I had taken detailed photographs, they can only help so much in terms of instruction. Essentially, this part of the process is sculpture, and you just have to make it up as you go along! I create shapes by wadding up newspapers and wrapping them with masking tape, then taping them to the box. It evolves organically over time, and I change it while I go, turning the head around to view it from various angles and just trying to make it look as cool as I can. The most important piece of advice, particularly if you're building on a box or balloon, is to do whatever you can to disguise the shape of your starting point. You don't want your mask to look like a box with a face, or a sphere with some pieces stuck on it... you want to incorporate that starting shape into the overall design and bury it beneath the face you're sculpting! On this mask, for example, I added the dome-shaped top and used another strip of cardboard to make a very angular, jutting chin, which helps to diminish the boxiness.
So, if you want to make an exact copy of my mask, then my first instruction is "MAKE A MASK OUT OF CARDBOARD, PAPER AND TAPE THAT LOOKS EXACTLY LIKE THIS."
Otherwise, start by experimenting with a way of sculpting the mask that is comfortable to you. It took me a while to find a method that worked for me, and everybody's different. Just bear in mind that the more materials you use, the heavier your final mask will be... and even though it's just flour and newspaper, the papier-mache will add quite a bit of weight.
You can see from the pictures here that I did not really start taking photographs until just after I started to coat the mask with papier-mache. The nails sticking out of his head posed certain problems, to ensure that they would stiffen and set at the correct angle. I tied the nail from his right eyelid to the nail protruding at the back of his head to keep it propped up while the flour-paste dried.
63 comments
1-40 of 63next »
Oct 21, 2010. 10:44 AMMasko says:
Your design for this mask real well done. Myself mask maker and think your real good with show character mask.
Oct 13, 2010. 12:18 PMjimboburgess says:
OSWALD
Oct 20, 2009. 11:22 AMmelartweaver says:
Did you do the hands the same way?
Oct 20, 2009. 11:20 AMmelartweaver says:
One other thing-- I had to do mache that would allow light to come through, so I found that good, thick paper towels worked well for that and didn't require as many coats.  The light came through great--just like a lamp!
Oct 20, 2009. 11:16 AMmelartweaver says:
Great instructable!  I just did a bunch of paper mache and really like your idea to puree the paper.  (I used The Onion as well.  Ha ha!)  I just want to add that Kilz has bleach in it which is great for preventing mold.  I read you can add it or paint to the mache mix which makes it more weather proof and sturdy, and also makes the mache less porous when it comes time to add your final color.  Also, adding salt to the mix keeps the mold out.  (I can't remember if you said you used salt...)  Anyhow, great mask.  I'm inspired!
Oct 9, 2009. 3:48 AMmarkham101 says:
Stunned by your talent.  I have always been a fan of the oversize mask, haven't even considered to try until now.  I think some small scale paper mache projects would be great for my kids and get me back into the creative mode i have stored away for too long.  I'm going to go over you other postings before I ask any of the questions that are in my head.
Dec 29, 2008. 7:41 PMlogan74k says:
Jaques. Jaques seems to fit. I like the butcher/mortician idea, I assume this has already gone out for Halloween, how did that go?
Nov 11, 2008. 6:46 AMhankbeast says:
Awesome job dude. I've always loved your work anyway so voting for you was a no brainer. SW
Oct 29, 2008. 5:19 PMThe Red Button says:
the blue one is still being worked on oh btw i like covering them with tape before i paper mache them because i have had horrible problems with paper mache being too wet and ruining the cardboard structure that holds my mask together
Oct 29, 2008. 5:22 PMThe Red Button says:
and i use tinfoil for the shapeds except for the eyes i need to be able to scoop those out from the inside and paper crumbled up for that works best
Oct 28, 2008. 11:49 AMF-zero says:
I dont know if I did something wrong, but my paper mache mask was very stiff. It might have been my mixture. How exactly do you cut a hole in the paper mache? It was very hard to do and came out jagged. What tool do you use?
Oct 29, 2008. 5:27 PMThe Red Button says:
i used a drill to cut my eyes
Oct 29, 2008. 10:13 PMF-zero says:
Ah, alright, thanks. I actually ditched the old one because it got lopsided wihle i was making it :p I think this one will work pretty well though. Great insturctable by the way. It really shows the possibilities of paper mache! Infact, I couldn't even tell your mask was made of paper mache.
Oct 17, 2008. 2:18 AMHazanko says:
I think the name "Elijah" would be cool. Also, while your costume is great in it's own right, I'm not too crazy about the arms/jacket going with this particular face. I really think a face like this needs a straight jacket, dirty and stained, and with the hump tearing through the back (I see now you did that to the coat: great minds...). throw on some ruddy jeans and a pair of over-sized work boots with stakes through the toes, and finish it with some silver-clasped belts wrapped around your upper thighs. Maybe even some kind of shock collar, to hide the small neck area. You'd look creepy hopping around, as well as sprawled out on a sofa. Oh, and laughter is good, but not as good as quick...manic...heavy...breathing. Overall, though, an excellent intructable. A++. Would buy from again. All that jazz.
Oct 7, 2008. 11:34 PMunseenoyster says:
Bravo! This is one of the coolest indestructible on here. (In my personal opinion) I love all things sculptural, and enjoy the odd paper mache project every now and then, but my stuff has never reached such unbelievably fantastic proportions. I'm hoping to experiment with the paper-mush that you spoke of. Does it do damange to the pot you use for boiling, Should I get one specifically for paper boiling? I'm told that the blender should be task specific, and not to mix paper blending with food blending.
Oct 3, 2008. 2:06 PMVladimyr says:
I have a question about wearing that monster! Did you build in some sort of support system for it rest on your head/shoulders/both? I'm very curious about how exactly you wear it. It's obviously very large and certainly it can't just sit on your shoulders.
Oct 2, 2008. 3:22 PMpstephens says:
Man! That's awesome. However, it must take forever.
Sep 7, 2008. 5:26 PMshadowfluid says:
this is great! you are an accomplished artist! however, i think many people would like to see, at the least, one picture of the mask actually on you or someone else head. nice job!
Sep 23, 2008. 7:18 AMshadowfluid says:
HaHa! nice! thanks for the pics! i'm sure that everyone on instructables will enjoy seeing them! Can't wait to see the giant monster hands when they're done! Will you be making an 'ible on those as well, perchance?
Sep 11, 2008. 9:48 AMVladimyr says:
I don't have any ideas for a name, but if you wanted to go with the "butcher" look you talked about you should look at the MacFarlane Toys Jack the Ripper toy. He has a bloody apron with a chain belt with various knives and hooks hanging from it. Very disturbing.
See the toy here!
Sep 8, 2008. 11:06 AMnorml says:
How about "Cuddles" with blaze orange scrub pants over stilts and a straight jacket?
1-40 of 63next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:pokiespout
I Build Monsters
