Giant Paper Flower Wall Decor
3,171
19
Posted in CraftPaper
Introduction: Giant Paper Flower Wall Decor
About: I am mom of 2 adorable girls, crafter, baker, photographer and DIYer
I have a very simple tutorial to make a modern giant paper flowers.
You don't need fancy tools or paper.
The tutorial is long to read but it quick to make. I spend 3 evenings making 7 flowers.
If you have any questions i will gladly answer them!
Step 1: ​Here Is What You Need:
65lb 8,5x11in Paper, any size will work as you will create your own template depends on the size
printer paper to draw your template
pencil
scissors
any cardboard to use as a base
something round(plate) to make a base
hot glue gun and sticks
masking tape to stick your flowers to the wall
Step 2: Templates
For the flowers you will need 3 different sizes of the petals.
Draw petals on the printer paper. Don't forget to mark the middle at the bottom.
For very big flowers make the length of the petal equal to the length of your paper. To save more paper and make lots of petals make sure your middle petal is no more then a half of your paper and you can use another half for the small petals.
For full flower you will need 6-7 big , 6-5 medium and 4-5 small petals
To make petals looks perfect mirrored draw your petal then fold it in a half length and cut using your draw line from 1 side only.
Cut a 2cm slit at the base of the petal.
Draw big leaves from different shades of green paper and cut
Step 3: Curling Petals
Use pencil to curl tops of the petals to the back
Step 4: Petals
Before gluing the slit try different flaps, the more you make flap the more your petal will stand straight. Using hot glue gun glue on the inside edge and over lap the slit.
Repeat this step with all petals.
Step 5: Making Flower
To make flower base cut the 10-15 cm circle from the cardboard.
Arrange big petals around base overlapping a little bit and glue them to the base
Glue the 2 and 3 row of petals making 1-1.5cm distance between rows.
Step 6: Flower's Center
To make flower's center take the paper and cut it in half vertically then fold in half vertically.
Cut fringes on the folded side
Roll up fringed paper gluing by hot glue gun all the way to secure. Add another strip to make the roll thicker.
Glue to the middle of the flower using hot glue gun
You are done with your flower!
Step 7: Flower Number 2
To make smaller flower you will need 3 different sizes of the petals.
Draw the big petal in size of the wide side of your paper. Arrange 2 different sizes on the 1 sheet of paper.
Repeat Steps 4 and 5
Step 8: Flower's Center
To make fancy center cut the 10-12cm circle
Fold in half
Draw a 3cm circle in the middle
Draw 1cm circles around, add 0.5cm thick lines and cut
Using hot glue gun glue it to the middle of the flower
Cut another small circle and clue in the middle
You are done with another flower!
Step 9: Poppy Like Flower
For the poppy like flower you will need only 1 petal's size.
Make template in size no more then the half of the paper to have 2 petals from 1 paper.
You will need 15 petals
To make a center, cut two 10-12cm circles, cut the fringes around, glue together. Glue them to the middle of the flower.
To make another center cut 7cm circle, fold it in half 3 times,
You should have 6 triangles around.
Make a 0.5cm cut on every fold and make every bottom a little bit round, then fold it inside. You will use it to glue you center
cut one of the folds till the middle of the circle, overlap 2 triangles and clue together
Glue this to the middle of the flower.
Now you have one more flower.
Step 10: Flower Number 4
To make this flower repeat steps 2, 4 and 5
To make the center repeat step 8 and the center from step 9
Step 11: Knapweeds Flower
To make Knapweeds flower you will need 12 light blue petals in the same size.
Repeat steps 2, 4 and 5 just make sure you are not overlapping petals and put the second row like the first one to have gaps between petals.
Make the center from step 9 in two different sizes in purple and blue colours. And remove every second fringe from the centers. Glue it to the middle of the flower
Step 12: Daffodil Flower
To make Daffodil you will need 6 wide petals.
Fold each petal in half to make it looks fuller.
Do not cut slits
using hot glue gun glue the petals to the base overlapping each petal.
Cut 5-7cm circle to cover the base and the bottoms of the petals.
Cut 5 cm wide the long strip. Make small cuts, fold it, glue the sides and glue the center to the middle of the flower.
Cut the green circle and glue it inside the center cup
To make stamens fold orange paper, draw a stamen and cut. Glue them inside the cup
Step 13: Flower Number 7
To make this flower repeat step 12
To make the center cut 4-5cm wide long strips
Fold them longwise , cut the fringes not from fold side.
Roll up using pencil.
Using hot glue gun glue fringes starting from the center of the flower , add strips as necessary
Step 14: Simple Chamomile Flower
To make simple chamomile flower you will need 16 same size petals.
Repeat step 12 and make 2 rows
For the center repeat step 9
Step 15: Wall Mounting Option
As I'm renting condo i'm not allowed to make a holes in the walls.
To mount paper flowers I use a masking tape
Cut a smal strip, make a circle and stick it to the base of the flower. The heavier the flower the more strips you will need
Step 16: Arrangements
Now you have lots of flowers in different sizes.
Stick them to the wall and add leaves.
Papercraft Contest 2017
Runner Up in the
    • Slow Cooker Challenge
    • Spotless Contest
      Spotless Contest
    3 Comments
    So beautiful! Thanks for sharing!
