Giant Spider With Webified Victim!
Introduction: Giant Spider With Webified Victim!
Halloween Decor Contest
First Prize in the
Huge 20 foot arachnid with suspended 'victim' wrapped in it's web! I spent approximately $40 utilizing much of the supplies from around my house.
Materials needed:
8 ft sections of 1/2 inch pvc x 10
45 degree x 18
90 degree x 8
PVC T's x 8
Plywood board
Styrofoam block(or similar material)
Yoga ball-my wife won't miss
Carpet remnants
Black parachord
Packing tape
Black/yellow paint
Spray foam- 1 can
Solar landscaping globe lights x2
D ring x2
Twine(free at check out)
Heavy duty black trash bag X 1
Step 1: Cuts
Cut a piece of plywood down to 2x3.
Cut your pvc 'legs' into various sections, 2, 3 or 4 feet. I made my rear legs with a longer reach.
I made my 'striker' legs a bit shorter but with more articulation with an extra 45 degree joint.
Find some sort of material for the body, I used a yoga ball but you can simply fill a tash bag with stuffing. I found some square styrofoam blocks from a recently purchased coffee pot and taped it together to help form the abdomen along with the yoga ball.
I cut out some wholes in the styrofoam body to insert my solar light eyeballs.
I attached 2 D rings to the back of the plywood.
Step 2: Build the Body
I cut 3, 2 foot sections of pvc and attached them horizontally to the underside of the plywood by drilling holes one other side of the pvc pieces and using zip ties to fasten them. I backed up the zip ties with a small screw through the plywood. Where the pvc terminates attach a 90 degree angle. I did not use pvc glue on any of my joints but used a small screw as a 'set screw' to lock them in place and so it could be disassembled for storage.
Step 3: Build the Legs
I experimented here with different configurations of 45's with different lengths of pvc, but I made both rears the same, both middles the same, etc. The 2 'striker' legs in the front are a shorter set with an additional 45 joint so they look more articulated. I terminated all the legs with a T fitting. I later zip tied small squares of upside down carpet to give him some spidey grip to the roof.
Step 4: Abdomen
I used a styrofoam block from a coffee maker which I glued together to form a square. Behind it I placed a yoga ball which was taped down with red carpet tape. I covered the whole thing with a heavy duty trash bag and pulled to to the front to make the mouth-like area. I carved out 2 holes and drove in solar globes for eyes. They don't shine as bright as I had hoped so I would consider an upgrade here. Of course They were only 1.99 each! I covered the whole thing with a spider web bungee to keep it all together, how fitting.
Step 5: Prep the Legs
I drilled a small hole through either end of the pvc leg sections and threaded twine(free from the checkout line at lowes!). I loosely wrapped the legs and tied it off. I then spray foamed the legs, my hope was that the twine would give the spray foam more of a hold on the pvc, which it did! I didn't foam the last segment in order to conserve foam and I thought it would be a good effect to differentiate the sections.
Step 6: Hire Oompa Loompas
These two Oompa Loompas were brought on board to paint the legs. It's a family affair.
Step 7: Raise It Up
All components were raised up along with a bucket of supplies. Thanks for helping mom.
Step 8: Placement
The back legs were added to the body on the back side of the roof. Parachord was lasooed around the chimney and secured to the rear of the plywood with the D rings. Spidey was sent over the the ridge of the roof and maneuvered into place.
Step 9: Back Around Front...
Mid, front and strikers were added from the front. As a last minute thought I looped parachord through the T's at the end of the legs and threaded it to the other legs. One sent up the left legs and one up the right legs. This helps to hold them into place. I would consider doing this to a top section of the legs as well and securing them back to the main line to further stabilize the legs and prevent them from laying down.
Step 10: The Victim
Skull from the craft store atop a roll of plastic and some old shoes with the whole thing wrapped in webbing. He hangs from twine from the gutter. Baby spiders were added later. I hope there will be a giant spider in your neighborhood soon! Please vote for this Instructable for the Halloween decor contest, if you dare!
Step 11: The Babies!
Spider spawn!
  • Science of Cooking
    Science of Cooking
  • Trash to Treasure
    Trash to Treasure
  • Paper Contest 2018
    Paper Contest 2018
F*** Halloween, everyday decoration! Got my vote :-)
Works well with a red house....
fantastic project to do with the family!
Thank you all for all the pos comments!! I'm not a pro so it is all very motivational! This is a great community with great creativity.
Really cool project. Great instructable to show how simple it could be. I love that you got your kids involved in the project too.
Over the top decoration! I love it!
Are you still inviting friends? ;)
Awesome project!
Thank you all! Thanks for all you contest votes as well, truly appreciated.
