This is what you'll need to make a giant toothbrush: Foam sheathing, acrylic paint, paint brushes, a hot glue gun, a surface smoothing tool (like a ch...
Use a nice size paint brush (not too big and not too small) to paint the toothbrush with acrylic paint. Don't use anything other than acrylic paint, l...
Outline a square/rectangle around the scrubbing brushes, which will be used as the bristles, to make an outline for the head of the toothbrush and rep...
Drill a whole into the neck of the body of the toothbrush, and into the head. Make sure the hole is centered and deep enough so you can stick a pencil...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
