Introduction: Gift Cards --> Guitar Picks!
Are you running out of guitar picks? Bored of plain colours and logos? Why not make your own guitar picks!
It's easy and can be done with things lying around the house.
First find some old gift cards, not the floppy ones but the plastic ones - you can guess how strong they are to how strong a guitar pick you want!
There are three main methods in order to create a guitar pick from these gift cards.
Step 1: Method 1 - Scalpel / Craft Knife
1) Use a pre-existing pick to sketch out a template to cut, or sketch your own exciting shapes!!
2) On a cutting board use a craft knife to carefully cut through gift card (score first then go deeper in progressive layers)
Step 2: Method 2 - Scissors
2) Cut around outline using scissors, may need to start out rough then trim down as you get closer to the line to cut.
Step 3: Method 3 - Pickmaster / Pick Shapped Press
No marking up required. Just use your press, line up on card and press down to create your pick - easy to get multiple picks out of one card as no rough edges to sand down or other bits of the card cut.
Step 4: Results
All done and lots of new guitar picks can be created quickly, cheaply and with exciting designs!
Great for reusing gift cards from Christmas when your done with them or if you have thrown away your gift cards just pop into Starbucks and pick up a load from their counter - you don't need to load them up!
Note for all methods you may want to sand around edges to prevent any burrs.
ENJOY!!
Reuse Contest
Unusual Uses Challenge
Before and After Contest
