Step 3Mixing the Beer
This set is based completely on your personal taste, and how long your plant has been growing - the longer you've been feeding it the more ginger flavor there is...the good news is that if you get it wrong you can fix it later.
The process is to take ~1-2 gallons of 'clean' water (boil tap water) add sugar until it is sweet - like juice, maybe a little sweeter.
Now using a paper towel strain the plant liquid out of the rest and add the plant fluid to the sweet water.
Bottle the mix in the 20 oz bottles - only fill them 2/3 full because a LOT of CO2 will be produced and the bottles will explode if they are too full (air compresses more than fluid).
Place all of your bottles in an opaque rubber maid tub and place it in a warm area. Check it every day, squeeze each bottle and if you cannot compress it crack the lid and let off the pressure - the soda bottles will take ~100 psi before they explode, but if they do explode you will be cleaning sticky ginger juice off the walls for ever. Alternately you can get a fancy carboy with a water lock and carbonate your beer later.
You might try some basic beer yeast or maybe a wine yeast - wine or champagne yeast is usually capable of reaching higher alcohol content.
