Step 4Let your imagination go wild - Royal Icing time
Royal Icing recipe
1 egg white
1/2 teaspoon lemon juice
1 3/4 cup confectioners sugar (powdered sugar)
Royal Icing
The traditional way to make Royal Icing is to beat egg whites and lemon juice together, adding the powdered sugar until the mixture holds stiff peaks. With modern concerns about salmonella from raw eggs, you can either use powdered egg whites or heat the egg whites first to kill any bacteria. With the heating method, mix the egg white and lemon juice with a third of the sugar, heat in a microwave until the mixture's temperature is 160ýF. Then remove from microwave, and beat in the remaining sugar until stiff peaks form. Using the powdered egg whites method, combine 1 Tbsp egg white powder with 2 Tbsp water. If the icing is too runny, add more powdered sugar until you get the desired consistency. Fill a piping bag with the icing to pipe out into different shapes. Keep the icing covered while you work with it or it will dry out.
Add Comment
