Step 2The Design
iImage Information
Using graph paper makes it easy to make a symmetrical design. I just freehanded one side of the giraffe, trying to visualize a 2D version of the 3D idea in my head, and then copied it by counting squares on the grid. I tried to draw through some corners of the grid, to make it easier to copy on the other side. Alternatively, you could draw one side, cut it out, fold it down the middle, and draw the other side. I designed a front, and a pair of legs for the back. Draw a small pair of half-circle ears, too.
Mark holes where we will put rivets through to connect the two pieces. Make sure the holes are the same distance from the bottom of the feet.
Cut out the designs to use as templates for the metal. Use a scriber tool or a sharp metal implement to transfer the outline onto the steel sheet. Use a center punch to mark the rivet holes.
