Girly duct tape wallet/clutch by jerseygirl77
Step 2: Tape the base together
Make one strip of duct tape either by using the loose leaf or just by lining two strips up together.
Cut two lengths about 3" to 3.5" long. Fold them in half long ways and then cut them into triangles. (see the picture). Then tape these to the short sides of the smaller sheet. Then tape the long side of the small sheet with the smaller sides of the triangles to the large sheet at the fold between the two larger sections.
Then finally tape the free sides of the triangles (in orange) to the middle section of the big sheet so that you get a pocket big enough for money.
This sounds confusing but I think the pictures make it relatively clear.
karinaward2010 says: Jul 3, 2011. 5:15 AM
could you please upload a video? i can't seem to find it. thank you
LexaLollipop says: Feb 1, 2011. 8:46 PM
The only confusing part was the color changes from picture to picture >.<
redlizard5 says: Jun 9, 2010. 4:44 PM
how big is the strip for the money pocket
jerseygirl77 (author) says: Jun 12, 2010. 5:16 PM
the same width as your main base and as for height it should be about a centimeter shorter than you want the wallet itself to be. Room to fold the top down but big enough that it covers the money.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
