Give User Shutdown and Reboot Privileges in Raspberry Pi
Introduction: Give User Shutdown and Reboot Privileges in Raspberry Pi
After turning Raspberry Pi into a multi-user desktop environment, we will find that all users (except pi) are very restricted in the system-level commands they can run. For example, clicking on the shutdown or reboot buttons doesn't work because these users don't have the privilege to run the shutdown or reboot commands.
sudoer policy detemines the privileges with respect to the commands.
Complete the "Turn Raspberry Pi into a multi-user desktop environment" instructable.
This instructable will show how to:
  • Configure the sudoer policy file
  • Test
The following are data of the 2 Raspberry Pi:
Distributor ID: Debian
Description: Debian GNU/Linux 7.8 (wheezy)
Release: 7.8
Codename: wheezy
Linux 3.18.9+ #767 PREEMPT Sat Mar 7 21:41:13 GMT 2015 armv6l GNU/Linux
man 5 sudoers
Step 1: Turn Raspberry Pi Into a Multi-user Desktop Environment
Step 2: Activate the Password for Root (Optional)
If we make a mistake in sudoers policy file, the pi account's sudo privilege will not function. This means we are NOT able to do any sort of configuration as it requires the sudo privilege and therefore the system prevents us from fixing the error in sudoers policy file. This is very troublesome. I know of two solutions:
  1. Activate the password for root
  2. Shutdown Raspberry Pi device, pull out the SD card. Find a running Linux system with an SD care reader. Insert the SD card into the D care reader. The running Linux will mount the SD card under /media/xxxxxx. Enter that directory and fix the sudoers policy file.
I prefer the first solution and as such this instructable will cover the first solution.
Open terminal emulator
Change root password:
sudo passwd root
Step 3: Add a Test User (Optional)
You may skip this step if you have previously created a user. Use the user id that you previously created for the next step.
sudo useradd jill
sudo passwd jill
Step 4: Assign Shutdown and Reboot Privileges to User
Determine the full path to shutdown command:
which shutdown
Determine the full path to reboot command:
which reboot
Create a new sudoers policy file to to include shutdown and reboot commands as new privileges
sudo vi /etc/sudoers.d/common_users
<br>User_Alias      PLEBEIANS = jill
<br>PLEBEIANS    ALL = NOPASSWD: /sbin/reboot, /sbin/shutdown
Save the file
If we want to add more commands besides those 2, add a new command next to "/sbin/shutdown". Each command is seperated by comma and 1 space.
If you want to add more users to have the two privilege, add new user next to "jill". Each user is seperated by comma and 1 space.
Step 5: Test Reboot and Shutdown
Click on Main Menu -> Shutdown -> Reboot
Click OK
Expected Result: The Reaspberry Pi device reboots
Step 5 Test Shutdown
Click on Main Menu -> Shutdown -> Shutdown
Click OK
Expected Result: The Reaspberry Pi device shutdown
Step 6: Debug (If Necessary)
If you completed "Activate the password for root" step:
su -
Type root password and press ENTER
Make the necessary changes and save the file.
Repeat "Test Reboot and Shutdown" step
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
