Step 4Set up Processing
To make our programming job easier, we'll use a number of different libraries inside Processing.
- Download the Arduino library for Processing from http://www.arduino.cc/playground/Interfacing/Processing. Extract the zip file to your Processing libraries directory - on the Mac this is in ~/Documents/Processing/libraries/arduino (I had to create libraries subfolder by hand since there was no other library installed yet.) Restart Processing and check under Sketch->Import Library... You should see an Arduino entry.
- To post twitter updates, download the twitter4j library from http://yusuke.homeip.net/twitter4j/en/index.html. Extract to some place you'll remember. We'll only need the file twitter4j-2.0.0.jar (your version may vary). Later on, we'll add that jar file to our Processing sketch through Sketch->Add file. This copies the jar file into a "code" subdirectory of your sketch. (It won't show up as a library).
- To post images via FTP, download edftpj library from http://www.enterprisedt.com/products/edtftpj/. You'll later add the jar file lib/edtftpj.jar to your sketch. There's more documentation about using this jar in processing at http://processing.org/hacks/hacks:ftp
- If you're on Windows, you'll need to download and install WinVDIG 1.01 (version matters!) so the Processing video capture library can grab frames from your webcam. Download from http://www.eden.net.nz/7/20071008/
Add Comment
