3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Give Your PC A Port Hole
Put Plexiglass in your computer in less than an hour.
Step 1Cut the case
Cut the case
This is a pretty obvious step but whatever. A more obvoius step would be to remove the side of your case before you begin cuting but again this it up to you. Unless your incredibly brave you might want to preclude this step with some thought and some measuring and marking and whatnot but after the step requring carefull thought you can go to the step requiring powertools . I used an adustible hole cuter set a little over 4 inches if you dont have one you could use a jigsaw or just a normal hole cutter fom your local home depot the adjustible one you can find at woodworkers warehouse. At any rate clamp the piece down very well, wear eye protection, be sure to lubricare with wd40, and most importantly take your time.
7 comments
Dec 26, 2011. 9:30 AMtlynch1 says:
i did something similar to a friends computer he needed 2 holes for water cooling hoses
used the coolest tool for the purpose i borrowed from my welding instructor
called a chassis punch a really epic tool that made perfectly clean holes only needing a light sand to take the burr off
Drill hole for the bolt
then thread the other half of the tool on and use wrench and ratchet till it cuts all the way through
boom perfect clean hole
they're expensive but so awesome for something like this !!! ( we did not even need to remove the internal components really just lay in a towel for the shavings for the pilot t hole.)
May 27, 2008. 10:55 AMvolund says:
why don't you just use a drill with a Hole saw on it? I would think that it would be easier than the drill press.
Sep 6, 2006. 6:04 PMTheCheese9921 says:
i got it, somehow cut out your name or a cool pic or biohazard ect. and put plexiglass in that
Jul 30, 2006. 3:19 AMScooterSES says:
Tips for a more clean look: Cut a sheet of acrylic (plexiglass is a brand name) bigger than the wholes and attach it to the back of the side panel. Add thin trim (something like automotive trim, just not ugly and silver) around the hole.
Jul 29, 2006. 8:23 AMTheCheese9921 says:
cool idea but why not just cut a big hole in the side and put a big sheet of plexiglass in it I'll post an instructable on how to do that if I do on the pc I'm building now.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:SmokeyTheBear
