Give a New Life to Your RC Toy Car
2,493
37
Published
Introduction: Give a New Life to Your RC Toy Car
Time to take out your remote control toy car and give it a new life with Annikken Andee.
Build the RC car of your dreams by controlling the car with your mobile phone, Annikken Andee lets you customise the UI on the Arduino IDE. Add more buttons to add function to your car, like sensors and buzzers. Ready set go! Start Making!
Materials Needed:
- 1 DRV8833 Dual DC Motor Driver
- 1 Arduino Uno
- 1 Annikken Andee U
- 1 Bread board 1 remote car include two DC motor, 4 LED Lights
- 1 Buzzer
- 2 Ultrasonic
- 1 Proto Shield Board
- Bluetack/Tape
- Styroform
- 5 x AA battery and 12V battery
Tool Needed:
- Arduino IDE
- Screw driver
- One soldering kit
- Annikken Andee resources (online at http://resources.annikken.com )
Step 1: Connecting Everything Together
DRIVER - ANDEE
GND - GND
BIN1 - PIN 10
BIN2 - PIN 9
AIN2 - PIN 6
AIN1 - PIN 5
DRIVER - DC MOTORS(M1 AND M2)
BOUT1 - M1 DC MOTOR
BOUT2 - M1 DC MOTOR
AOUT2 - M2 DC MOTOR
AOUT1 - M2 DC MOTOR
DRIVER - POWER SUPPLY
GND - SUPPLYGND
VIN - VOLTAGE
Front motor
  • BIN1 9
  • BIN2 10
Back motor
  • AIN1 5
  • AIN2 6
LEDs
  • Front LED 7
  • Back LED
Front Ultrasonic
  • Trigger - A0
  • Echo - A1
Back Ultrasonic
  • Trigger - A2
  • Echo - A3
Buzzer
  • PIN 3
Do not connect to PIN 8, 11, 12, 13 as Annikken Andee is using those PINS
Step 2: Connecting the Motor Drive
This is how we are going to connect the Motor driver to the desired assigned pins and to the remote controlled car.
Step 3: Soldering the Motor Driver Onto the Board
This is the overview of how the board looks like after soldering the motor driver onto the board with the PINs connected. As you can see, there are red wires connected from the motor driver to the assigned pins and there are two black wires which is connected to the resistor which is also connected onto the ground. They are for the LEDs light where all your black wires of the RC LED were suppose to connect to and there are also two red wires which are connected to PIN 7 which are also for the LED. In this example there are only two black and two red wires when there are suppose to be 4 red and black wires for 4 LEDs but because the the back LEDs of the RC car that was used in this example is faulty. Not to worry the codes are still made available in the source code and for the wiring it's the same as before but the red wires should be wired to the desired PIN you want unless you want to light up all four LEDs with just one PIN.
Step 4: Breadboard Connection
This is the breadboard connection that was used, starting from the left hand side is the white cable which is to the 5V on your proto board and the black cable to the ground. For the other cables, they are for the utlrasonic sensor as they require the 5V connection and also the ground connection.
Step 5: Ultrasonic Sensor
Previously we connected the VCC and the GND of both ultrasonic sensor to the breadboard. Now we are going to connect their trigger and echo onto the Proto board. The image above is the overview of the ultrasonic sensor triggers and echo pin connection on my proto board.
Step 6:
Now to complete the wiring for the entire RC car we need to include the buzzer connection at PIN 3 (orange cable) and to the ground(blue cable).
Step 7:
After finishing up the wiring we are left with the reassembling everything back to together. So here is the overview of the entire car after bluetacking the wires and the ultrasonic while taping the styroform to the front and back of the RC car to prevent damages inflicted to the ultrasonic in cases where the car is unable to stop in time and launches for an impact.
Step 8: Going Through the Source Code, Part 1: Declarations
* Pins declaration
// Front motor PIN
#define BIN1 9 // Left
#define BIN2 10 // Right
// Back motor PIN
#define AIN1 5 // Down/Backward
#define AIN2 6 // Up/Forward
// LEDs PIN
#define LedFront 7 // LED Front
#define LedBack A3 // LED Back
//ultrasonic PIN
#define trigger A2
#define echo A3
#define fronttrigger A0
#define frontecho A1
//buzzer PIN
#define buzzer 4
* Variables Declaration
//Variables to check current state of the car
bool isMovingBack = false;
bool isMovingForward = false;
bool isRight = false;
bool isLeft = false;
//ultrasonic variables to calculate the distance
int duration, distance, front, back;
bool constant = false;
bool justStart = false;
//this is similar to a state change in term of the speed
int gear = 0;
//these two variables are used as a counter to
//determine or estimate the duration of the speed
//that the car is moving on
int speedCounter = 0; // gear 2 - 255
int speedCounter2 = 0; // gear 1 - 120 or below
//this is a global variable used to keep track of the current car's speed
int power = 0;
//this variable are used to load updating of UI once
bool loadOnce = true;
Step 9: Going Through the Source Code, Part 2 : Void Setup()
void setup() {
// put your setup code here, to run once:
// Initialize driver control pins
// DC Motor
pinMode(AIN1, OUTPUT);
pinMode(AIN2, OUTPUT);
pinMode(BIN1, OUTPUT);
pinMode(BIN2, OUTPUT);
// LED Lights
pinMode(LedFront, OUTPUT);
pinMode(LedBack, OUTPUT);
// Ultrasonic
pinMode(trigger, OUTPUT);
pinMode(echo, INPUT);
pinMode(fronttrigger, OUTPUT);
pinMode(frontecho, INPUT);
// Buzzer
pinMode(buzzer, OUTPUT);
// start with drivers off, motors coasting
digitalWrite(AIN1, LOW);
digitalWrite(AIN2, LOW);
digitalWrite(BIN1, LOW);
digitalWrite(BIN2, LOW);
// Initialize UI once checker
loadOnce = true;
// Andee
Andee.begin();
Andee.clear();
setInitialData();
// For debugging purposes: allows printing message to console during testing
Serial.begin(9600);
Step 10: Going Through the Source Code, Part 3 : Void SetInitialData()
void setInitialData()
// controls UI declaration
up.setId(0); // UI Id
up.setType(BUTTON_IN); // type of UI
up.setLocation(2,0, ONE_THIRD); // location/position of the UI
up.setTitle("Up"); // UI title text
up.requireAck(false); // require no acknowledge for multiple tapping
left.setId(1);
left.setType(BUTTON_IN);
left.setLocation(3,1, ONE_THIRD);
left.setTitle("Left");
left.requireAck(false);
down.setId(2);
down.setType(BUTTON_IN);
down.setLocation(3,0, ONE_THIRD);
down.setTitle("Down");
down.requireAck(false);
right.setId(3);
right.setType(BUTTON_IN);
right.setLocation(3,2, ONE_THIRD);
right.setTitle("Right");
right.requireAck(false);
//speed control
topSpeed.setId(6);
topSpeed.setType(BUTTON_IN);
topSpeed.setLocation(0,1, ONE_THIRD);
topSpeed.setTitle("Increase/Decrease speed");
topSpeed.requireAck(false);
//honk
honk.setId(5);
honk.setType(BUTTON_IN);
honk.setLocation(0,0, ONE_THIRD);
honk.setTitle("Honk");
honk.requireAck(false);
//4 LED lights toggle buttons
frontLight.setId(7);
frontLight.setType(BUTTON_IN);
frontLight.setLocation(0, 2, ONE_THIRD);
frontLight.setTitle("Lights");
//backlights - the location might need to be changed in term of the size
//if it's included in, you might want to change from ONE_THIRD to ONE_QUART
//same for the rest of the buttons that are in the same row
//this is commented because the RC's backlight used in this example is faulty
backLight.setId(10);
backLight.setType(BUTTON_IN);
backLight.setLocation(0, 3, ONE_THIRD);
backLight.setTitle("Lights");
//halt/stop
kill.setId(8);
kill.setType(BUTTON_IN);
kill.setLocation(2, 2, TWO_THIRD);
kill.setTitle("Stop");
kill.requireAck(false);
//debug purposes can be removed after testing is done
displayText.setId(9);
displayText.setType(DATA_OUT);
displayText.setLocation(1, 0, FULL);
displayText.setTitle("debug");
displayText.setData("");
Step 11: Going Through the Source Code, Part 4
* Sound functions
//double purposes to get the distance for both front and back ultrasonic
void sense(int trig, int ech)
//ensure that the ultrasonic works
digitalWrite(trig, LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(10);
duration = pulseIn(ech, HIGH);
distance = duration/58;
void beep()
//Beep when reversing
//Beep when car reaches a certain distance between
//the back of the car and the object behind it
//check reversing
//Serial.println("Back");
sense(trigger, echo);
back = distance;
Serial.print("Back: ");
Serial.print(back);
Serial.println("cm");
if(constant == true)
if(back <= 120 && back >= 0) // distance <= 15cm and >= 0
//Serial.println("too close");
tone(buzzer, 956);
Halt();
else if(back <= 150 && back > 120) // distance <= 35cm and > 15cm
//Serial.println("close");
//Reduce speed
tone(buzzer, 1915);
delay(100);
noTone(buzzer);
delay(20);
power = 100;
if(isMovingBack == true)
if(isRight == true)
controlRightB(power);
else if(isLeft == true)
controlLeftB(power);
else
controlDown(power);
gear = 1;
else
tone(buzzer, 1915);
delay(200);
noTone(buzzer);
delay(20);
else
if(back <= 100 && back >= 0) // distance <= 15cm and >= 0
tone(buzzer, 956);
Halt();
else if(back <= 150 && back > 100) // distance <= 35cm and > 15cm
//Reduce speed
tone(buzzer, 1915);
delay(100);
noTone(buzzer);
delay(20);
power = 100;
if(isMovingBack == true) //car is moving backward
if(isRight == true) //still turning right
else if(isLeft == true) //still turning left
else //continuing moving back without turning
controlDown(power);
gear = 1; //speed that is currently at
else //no object within the distance of 150cm
tone(buzzer, 1915);
delay(200);
noTone(buzzer);
delay(20);
void frontbeep()
//the front of the car and the object infront of it
//check
//Serial.println("Front");
sense(fronttrigger, frontecho);
front = distance;
Serial.print("Front: ");
Serial.print(distance);
//running at a constant speed of 255
if(front <= 120 && front > 0)
Halt();
else if(front <= 150 && front > 120)
//Reduce speed
power = 100;
if(isMovingForward == true) // if car is moving forward
if(isRight == true)
controlRight(power); // still turning right
controlLeft(power); // still turning left
else
controlUp(power); // still moving forward
gear = 1;
else
noTone(buzzer);
else // running at a speed 120 or lower
if(front <= 100 && front > 0)
Halt();
else if(front <= 150 && front > 100)
//Reduce speed
power = 100;
if(isRight == true)
else
gear = 1;
else
noTone(buzzer);
void honkBeep()
if(honk.isPressed())
tone(buzzer, 1915);
delay(200);
Step 12: Going Through the Source Code, Part 5 : Honk and Lights
* Honk functions : works similar to pressing of button example
* just that it is used to trigger the buzzer
void honkBeep()
tone(buzzer, 1915);
delay(200);
* Light functions : similar to the honk function or how you normally
* code for turning on and off for an LED light
void light()
// Light up front lights
if(frontLight.isPressed())
frontLight.ack();
if (frontLightState == 0)
digitalWrite(LedFront, HIGH);
frontLightState = 1;
else
digitalWrite(LedFront, LOW);
frontLightState = 0;
// Not implemented as the RC car that was used has a fault with
// the back lights but the code is similar to the front lights
// Light up back lights
if(backLight.isPressed())
backLight.ack();
if (backLightState == 0)
digitalWrite(LedBack, HIGH);
backLightState = 1;
else
digitalWrite(LedBack, LOW);
backLightState = 0;
Step 13: Going Through the Source Code, Part 6 : Basic Control for RC Movement and Loading UI
* Movement functions
* 5 condition:
* - Move Forward: controlUp();
* - Turn Right: controlRight();
* - Turn Left: controlLeft();
* - Turn Right Backward: controlRightB();
* - Turn Left Backward: controlLeftB();
* - Move Backward: controlDown();
* - Complete stop: Halt();
* AIN1 - for moving backward
* AIN2 - for moving forward
* BIN1 - for turning wheel to left
* BIN2 - for turning wheel to right
void Halt()
//Serial.println("Halt");
if(constant == true) // if car is moving at a constant speed
if(isMovingForward == true) // moving at a high speed forward
Serial.print("650");
//pulling back the car against the current speed it's running at in order to allow the car to stop
//by using a certain amount of effort against the opposite direction
digitalWrite(AIN2, LOW); // stop wheel from moving forward
digitalWrite(AIN1, HIGH); // start wheel from moving back
delay(750);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
constant = false;
justStart = true;
else if(isMovingBack == true) // moving at a high speed backward
digitalWrite(AIN2, HIGH);
delay(750);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
constant = false;
justStart = true;
else
if(justStart == false) // car started moving for awhile
Serial.print("300");
delay(350);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
justStart = true;
delay(350);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
justStart = true;
else // if car just starting moving
Serial.print("100");
delay(200);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
justStart = true;
delay(200);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
justStart = true;
//debugging purposes, can be removed after testing
displayText.setData(distance);
displayText.setUnit("cm");
displayText.update();
// control
void controlUp(int p) // overwrite turning controls if up is pressed
//Serial.println("up");
analogWrite(AIN2, p);
isMovingForward = true;
isRight = false;
isLeft = false;
void controlDown(int p) // overwrite turning controls if down is pressed
//Serial.println("down");
analogWrite(AIN1, p);
isMovingBack = true;
isRight = false;
isLeft = false;
void controlLeft(int p)
//Serial.println("left turn");
if(isLeft == false) // left turn while moving forward
digitalWrite(BIN1, HIGH);
isLeft = true;
isRight = false;
else
// continue but different speed
isLeft = true;
isRight = false;
void controlLeftB(int p)
//Serial.println("left turn back");
if(isLeft == false) // left turn while moving backward
isLeft = true;
isRight = false;
else
isLeft = true;
isRight = false;
void controlRight(int p)
//Serial.println("right turn");
if(isRight == false) // right turn while moving forward
digitalWrite(BIN2, HIGH);
isRight = true;
isLeft = false;
else
isRight = true;
isLeft = false;
void controlRightB(int p)
//Serial.println("right turn back");
if(isRight == false) // right turn after while moving backward
isRight = true;
isLeft = false;
else
isRight = true;
isLeft = false;
// loading of UI
void UI()
//update once
frontLight.update();
//controls
up.update();
left.update();
down.update();
right.update();
kill.update();
//speed
topSpeed.update();
honk.update();
//displayText.update();
loadOnce = false; // UI loaded once
Step 14: Going Through the Source Code, Part 7 : Void Loop()
void loop() {
// put your main code here, to run repeatedly:
// only occur when speed is changed
//Serial.println("Low speed");
if(topSpeed.isPressed())
Serial.println("Top speed");
if(gear == 1)
Serial.println("g2");
power = 255;
if(isMovingForward == true) // check if car is moving forward
if(isRight == true)
else
else if(isMovingBack == true) // check if car is moving backward
if(isRight == true)
controlRightB(power); // still turning right
controlLeftB(power); // still turning left
else
controlDown(power); // still moving backward
gear = 2;
else if(gear == 2)
power = 120;
if(isMovingForward == true) // check if moving forward
if(isRight == true)
else
else if(isMovingBack == true) // check if moving backward
if(isRight == true)
else
gear = 1;
if(power == 0)
//Serial.println("Power more than 0");
if(up.isPressed())
power = 120;
gear = 1;
controlUp(power); // move forward
if(down.isPressed())
power = 120;
gear = 1;
controlDown(power); // move back
if(left.isPressed())
controlLeftB(power); // turn left backward
else if(isMovingForward == true)
controlLeft(power); // turn left
if(right.isPressed())
controlRightB(power); // turn right backward
controlRight(power); // turn right
if(kill.isPressed())
Halt(); // stop
else
if(up.isPressed())
Halt(); // stop
light(); // check lights and light up
beep(); // ultrasonic to beep, reduce speed and halt
else if(isMovingForward == true) // check if moving forward
frontbeep(); // ultrasonic to beep, reduce speed and halt
else
noTone(buzzer);
if(loadOnce == true) // update UI once
UI(); // update UI, loadOnce = false
honkBeep(); //honk
// rough estimation of the power used
// to hit a certain constant speed
if(power == 255)
if(speedCounter >= 4)
// assuming that the car is now at a state of constant speed
// after running at a power of 255 for maybe a rough estimated
// duration of 0.5
constant = true;
speedCounter2 == 0;
speedCounter++;
else
if(speedCounter2 >= 0 && speedCounter2 <= 5)
// the opposite effect of the above code
constant = false;
justStart = true;
else if(speedCounter2 > 10)
constant = false;
speedCounter == 0;
justStart = false;
speedCounter2++;
delay(100);
Step 15: Complete Source Code
// Define each component of the desired pin numbers that you want to assign to.
// noted: 8, 11, 12, 13 are being used by Anikken Andee hence the pins available are
// 0 - 7, 9, 10, A0 - A5
* Pins declaration
// Front motor PIN
// Back motor PIN
// LEDs PIN
//ultrasonic PIN
#define trigger A2
#define echo A3
//buzzer PIN
#define buzzer 4
int power = 0;
int gear = 0;
// Things you need to work with Arduino and Andee
#include
#include
//Front Lights
AndeeHelper frontLight;
int frontLightState = 0;
//Back Lights
//AndeeHelper backLight;
//int backLightState = 0;
//controls of car's movement
AndeeHelper up;
AndeeHelper down;
AndeeHelper left;
AndeeHelper right;
AndeeHelper kill;
//control of car's speed
AndeeHelper topSpeed;
//Debugging purposes to display debugging text
//AndeeHelper displayText;
//honk
AndeeHelper honk;
void setup() {
// DC Motor
// LED Lights
// Ultrasonic
// Buzzer
// Initialize UI once count
loadOnce = true;
// Andee
Andee.begin();
Andee.clear();
setInitialData();
Serial.begin(9600);
* Initialise/Declare UI
left.setId(1);
down.setId(2);
right.setId(3);
//speed control
topSpeed.setId(6);
//honk
honk.setId(5);
//halt/stop
kill.setId(8);
* Sound functions
void beep()
//check reversing
back = distance;
Serial.print(back);
tone(buzzer, 956);
Halt();
//Reduce speed
tone(buzzer, 1915);
delay(100);
noTone(buzzer);
delay(20);
power = 100;
if(isRight == true)
else
controlDown(power);
gear = 1;
else
tone(buzzer, 1915);
delay(200);
noTone(buzzer);
delay(20);
else
tone(buzzer, 956);
Halt();
//Reduce speed
tone(buzzer, 1915);
delay(100);
noTone(buzzer);
delay(20);
power = 100;
if(isRight == true)
else
controlDown(power);
gear = 1;
else
tone(buzzer, 1915);
delay(200);
noTone(buzzer);
delay(20);
void frontbeep()
//check
front = distance;
Halt();
//Reduce speed
power = 100;
if(isRight == true)
else
gear = 1;
else
noTone(buzzer);
Halt();
//Reduce speed
power = 100;
if(isRight == true)
else
gear = 1;
else
noTone(buzzer);
* Honk functions
void honkBeep()
tone(buzzer, 1915);
delay(200);
* Light functions
void light()
frontLight.ack();
else
backLight.ack();
backLightState = 1;
else
backLightState = 0;
* 5 condition:
void Halt()
delay(750);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
constant = false;
justStart = true;
delay(750);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
constant = false;
justStart = true;
else
if(justStart == false) // started awhile
delay(350);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
justStart = true;
delay(350);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
justStart = true;
else // if just starting
delay(200);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
justStart = true;
delay(200);
isRight = false;
isLeft = false;
power = 0;
gear = 0;
speedCounter = 0;
speedCounter2 = 0;
justStart = true;
// control
isRight = false;
isLeft = false;
isRight = false;
isLeft = false;
isLeft = true;
isRight = false;
else
isLeft = true;
isRight = false;
isLeft = true;
isRight = false;
else
isLeft = true;
isRight = false;
isRight = true;
isLeft = false;
else
isRight = true;
isLeft = false;
isRight = true;
isLeft = false;
else
isRight = true;
isLeft = false;
// loading of UI
void UI()
//update once
//controls
up.update();
left.update();
down.update();
right.update();
kill.update();
//speed
topSpeed.update();
honk.update();
void loop() {
if(gear == 1)
power = 255;
if(isRight == true)
else
if(isRight == true)
else
gear = 2;
else if(gear == 2)
power = 120;
if(isRight == true)
else
if(isRight == true)
else
gear = 1;
if(power == 0)
if(up.isPressed())
power = 120;
gear = 1;
power = 120;
gear = 1;
Halt(); // stop
else
if(up.isPressed())
Halt(); // stop
else
noTone(buzzer);
honkBeep(); //honk
if(power == 255)
// duration of 0.5
constant = true;
speedCounter2 == 0;
speedCounter++;
else
constant = false;
justStart = true;
constant = false;
speedCounter == 0;
justStart = false;
speedCounter2++;
delay(100);
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
