Give your HDTV the Philips Ambilight effect on the cheap
I love those Philips Amiblight HDTVs - you know, the ones with the rear backlight that projects colours onto the wall behind the TV? Not only does it look pretty, but if you're gaming or watching a film in low-light conditions then the backlight reduces eye strain.
I do suffer from eye strain. Mainly because I watch DVDs or game with only a lamp on. After an hour I'll start to get a headache. Problem is that the lights in my living room are too bright.
I'm perfectly happy with my Hyundai 32" HDTV and don't want to shell out for a Philips one... so it's Ikea to the rescue and you can get a similar effect for under $40.
Step 1Get the lighting from Ikea
OK, first up we need lighting. The lighting is called TRETTIOEN which comprises of 4 LED light strips, the mains adapter and some bendy wires for corners. It's available from all good Ikea stores.
I live in the UK where it costs £21 for the set which come in White, Green or Blue.
32 comments
Jun 27, 2011. 9:37 PMpwiest1 says:
Nice, simple fix to reduce eye strain, but you're only going to get white light this way -- not like the Philips Ambilight displays, which adjust the lighting according to what's on the screen. Fortunately, if you've got some technical aptitude you can get the same effect on any TV.
The use of an Arduino to control a string of colored LEDs has been pretty well documented -- search "ambilight arduino clone" or look up Amblone. The only problem is, most of these projects were designed for ambient lights on your monitor, based on software that runs on your computer. If you want to do this for a cable box or a Playstation, for example, you'd have to run the display through your computer via a capture card.
Dec 31, 2010. 1:57 AMaptilight says:
please, visit my web site - aptilight.ru.
i developed ambilight for dvi,hdmi,display port
thanks
Jan 21, 2009. 2:15 PMThreeWestCreative says:
This is a good idea no matter how you look at it. I'm used to CRTs and just got a 26" HDTV and it was great when it's light out but as soon as it got darker I'm like "wow this thing is crazy bright". I could turn down the brightness but it looks better as is. I happen to have a coil of rope lights I got from home depot but never used. They are easy strung around the TV or behind it and they are less than $20. Having more light behind or around the TV is better than having a light on for the whole room imho. The changing ambilights on the Philips TV is havoc on those of use who are easily sickened from things like that. :)
Mar 2, 2009. 8:46 PMsnowpenguin says:
Did you post this exact comment twice?
Mar 27, 2009. 4:30 AMcornflaker says:
LOL yes he did haha
Dec 23, 2008. 11:39 AMbaneat says:
To try it out, you should try a basic lamp pointed from behind your monitor to the wall behind it.
Aug 13, 2008. 5:15 PMPadlock says:
I did this, except with green cold cathodes meant for computer lighting @ xoxide.com
Aug 13, 2008. 10:02 AMpepitosbazzeguti says:
I have purchased today a blister of "dioder " at ikea store with the change of colors ,and assembled on my Toshiba LCD 32". In Italy a blister of "dioder" cost 59.90 euros,but the effect on tv is cool ! I prefer watch tv with led trimmed light blue or violet. Thank you for this Instructables
Oct 19, 2007. 11:42 PMSermos says:
I did this in an even easier fix simply by purchasing a string of LED xmas lights (blue color), then plugging them into the usb port on the back of the tv, and taping them on the back of the screen using masking tape. Its an easy fix, comes on when the tv turns on, and goes off when the tv goes off. Only costed a dollar, and 100% removable.
Feb 24, 2007. 4:40 PMLasVegas says:
Theoretically, if you have an RGB or VGA output on your video source, you could build a simple circuit to drive each of 3 light strings. The brightness would be based on the average level of each color line between vertical sync pulses. With high impedance inputs it wouldn't even interfere with the display. It would be a much more complex circuit to do it with component outputs (P Bg Yg) and even more complex with composite, but still possible.
Sep 26, 2007. 1:02 PMfastm3driver says:
Did you ever figure this out? IKEA sells a dioder now that can do RGB for $50. I am currently trying to find out how many I can hook up to one control unit. I am also going to take one apart one to see if there is a way to connect it to a computer to control the light output. Then it would be sweet to put together a box like you are talking about to make a ambilight device. maybe a thing that plugs into s-video and outputs to the dioder?
Sep 26, 2007. 1:25 PMLasVegas says:
You had me confused there for a minute. I didn't know what a "dioder" was! For others; It's an LED lighting strip.
A link to it would have helped...
Looks pretty cool... It would be fun to play with.
Sep 26, 2007. 1:41 PMfastm3driver says:
sorry, meant to include a link. I've tried to find some specific "dioder" hacking but all I come up with is people taping them to the back of their TV. I've looked into making my own array for a while but it is still pricey and a pain. The IKEA set is $50 and comes with 4 9"strips that can be arranged in many configurations. I bought 4 sets to mess around with because I'm trying to make a wall light up with 14 strips hung under 14 shelfs. The problem is I don't think the controller can handle all 14 together. So I'm looking into beefing up the power supply.
Feb 26, 2007. 8:53 PMtherealcmj says:
I've been looking for a device that does this, but so far have come up short. I'd bet that there's a good number of people that would love to have something like this. I'm a software, not a hardware guy... Any chance of a pointer to get me started.
Feb 27, 2007. 1:15 AMLasVegas says:
I've been thinking on this for a couple of months. I have a few ideas, but haven't brought them together yet. I imagine a PIC will be necessary to count the results of D/A of each line to generate the final color. I think an average would be sufficient and would be used to decide the brightness of each of the 3 colors. It would have to be rather fast to get a better average across the number of scan lines, as many as 1080 per 60th of a second (US). Currently tri-color LEDs are out of range for practical use, but it would be just as practical with ultra-brights of each of the 3 colors.
Jun 15, 2007. 11:27 PMbabylonfive says:
No, averaging the signals wouldn't work. You'd need to sample the video, count all the different colors, then pick the one with the most samples. Anything else would just average on most content to grey.
Mar 3, 2007. 1:45 PMdmacrae says:
You could actually avoid counting the sync pulses all together, and just average the input on each the r g and b pins (I'm not sure how RGB signals are formatted though. Then using a pic and a calibration dvd that shows black and white you could figure out a linear transform for the inputs to generate the lighting signal. P Bg and Yg would only require the proper adjustment in color space so that the reading system would be the same, and then the PIC would calculate the proper RGB signals.
Mar 3, 2007. 6:06 PMLasVegas says:
You'd want to keep track of the sync pulses to ignore the center of the screen. The ambient lighting would be most effected by the outside of the picture.
Feb 27, 2007. 11:39 PMclippership says:
This is quite nice. In the USA try using a rope light you can get at any big box hardware store, or better, use a small set of white Christmas lights since they put out much less heat.
Mar 6, 2007. 12:56 PMpsturgeon says:
Or - along the same thread - At christmas time - grab a string of LED christmas lights at your local drug store. Same thing, but less heat and less electricity used.
Feb 28, 2007. 3:23 PMColumbusGEEK says:
My good friend has the real deal and it looks fantastic.
Eye strain comes from watching tv too much. My revised solution instead of this is to turn off the tv after a few hours. :)
You are now part of the biased light group here. :p
http://www.instructables.com/id/EAKWQFEOQNERIE2WVJ/
http://www.instructables.com/id/EE79YDCL0REQZJI1AZ/
I like the leds, they seem way too bright in the pics though. I had to continually get smaller wattage bulbs to find one that felt right.
Feb 28, 2007. 1:15 PMSolarstorm says:
Here is another way to build an atmo light for an Linux Video Disk Recorder.
The site is in german:
http://www.vdr-wiki.de/wiki/index.php/Atmo-plugin
Here translated with Babel fish:
http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=de_en&url=http%3A%2F%2Fwww.vdr-wiki.de%2Fwiki%2Findex.php%2FAtmo-plugin
Feb 28, 2007. 7:38 AMapemon says:
That TRETTIOEN here in Finland is available only in blue & green.. Might not work as good :P Sucks
Feb 27, 2007. 1:35 PMrikemomo says:
I actually went and bought one of these lights:
http://www.goestores.com/catalog.aspx?storename=cinemaquestincn&DeptID=70357&ItemID=674596&detail=1
and just mounted the thing behind my TV. I guess the light temperature is designed to be more comfy on your eyes. It works quite well and was really easy to mount...
Feb 26, 2007. 3:21 PMPunkguyta says:
This isn't "Philips ambilight" at all, not even close. You're just sticking a light behind your tv, I could do that myself too, stick a lamp back there, easy as that. Like las vegas said, that would be a more complexe circuit, but would be the real thing.
Feb 26, 2007. 3:21 AMjeffreyf says:
It's great! You should add it to the Ikea Hacks group:
http://www.instructables.com/group/ikeahacks/
Feb 26, 2007. 1:20 PMjeffreyf says:
No worries. It's not the clearest thing. We're working on fixing that :) In the mean time, you first join a group, so for the Ikea Hacks group you'd join it, and then on the left under "groups" you should be able to add the Instructable to the group.
Feb 25, 2007. 12:19 PMcflowers says:
Nice...added it to The Daily Hack. Keep up the good work!
C. Flowers
TheDailyHack.net
Feb 24, 2007. 4:05 PMScoyle17 says:
It's a nice idea, though on Phillips T.V.s, the lights change colour to match what's on the edge of the screen. Though I'd say this does reduce strain to some extent.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jads
