3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Give your loved one a real "fallen star".
Give your loved one a real \"fallen star\".
Several times every year, the sky falls in.
Well, bits of it do - regular and predictable meteor showers happen all round the world, leaving burning trails across the sky as friction burns them away to nothing.
Or does it?
It may be romantic to name an anonymous dot in the sky after your loved one, but how about catching a real "fallen star" for them?
Step 1What you need:
What you need:
I'm sure you've realised that, when I say "fallen star", I really mean "meteorite". You hadn't? Well, you do now.
To catch the meteorites, you will need:
  • Magnets in a plastic bag
  • String
To view the meteorites, you will need:
  • A pair of non-magnetic forceps or tweezers - it is possible to manage with nimble fingers, but you are more likely to lose any interesting samples.
  • A microscope slide, preferably with a concave depression to stop things rolling away.
  • Clear nail varnish or "super" glue (CA glue, crazy glue)
  • A narrow-nibbed permanent marker.
  • A microscope.
129 comments
1-40 of 129next »
Feb 27, 2012. 9:33 PMXerxes09 says:
This is AWESOME! Thanks KiteMan for adding this
Feb 19, 2012. 3:10 PMstormy0314 says:
I haven't read all of the replies, so disregard if someone posted this earlier. I read an article that said get a large pasteboard/cardboard box, cover the bottom with white paper or cardboard and put it in an open space, not covered, but protected, and leave it there for a while. The best time is during a meteor shower, about every two months, in the even months. The little black spots recovered are probably meteorites. Remember that tons of space particles hit the earth daily.
Nov 18, 2011. 5:01 PMiminthebathroom says:
I am going to run this all winter, setting up a meteorite trap in a secluded space, then see what shows up in the spring.
Aug 28, 2011. 12:09 PMarpruss says:
I wish I knew how to verify with greater reliability whether they are micrometeorites. Anyway, here are some I found. The first one was a nice spherical one I lost. The third one is pretty but I am dubious if it's extraterrestrial. The second and third photos are at much higher magnification. In reality, they're as big as or smaller than the ball in the first photo. That's my excuse for even poorer focus. The photos were taken with point and shoot cameras hand-held to microscope eyepieces, with some loose-fitting adapters to make it easier. The first photo was with a Sony P100 through the 10X Huygens eyepiece that the microscope came with. The second and third photos were with a Canon G7 through a Rini 30mm telescope eyepiece, using my home-made telescope-to-microscope eyepiece adapter.
Aug 28, 2011. 3:19 PMarpruss says:
The last one has a bit of a melted look, but it didn't come through on the photo. The ball in the first one may be too uniform.
Aug 27, 2011. 11:38 AMarpruss says:
Today I tried using superglue to preserve a micrometeorite, but it crystallized in that nasty white way. I cleaned it off with acetone, and then just preserved them by putting them on a slide under a cover slip and taping the slip on.
Actually, I think it would look better on some white plastic rather than on glass--they looked better under the microscope when I put white cardboard under the slide. I was using a flashlight (and later reflected sunlight) to illuminate the slide.
I also found a nice trick for picking them up. You wet a toothpick with acetone. (Rubbing alcohol might work, too.) They stick for transit while the toothpick is wet, and come off easily because the acetone dries quickly.
Dec 6, 2010. 8:46 AMstargazer96 says:
is that acually a meteorite Kiteman
Dec 7, 2010. 2:16 PMstargazer96 says:
how is it posible though it looks really hard to do because i would like to do it but i dont have a pond
Dec 8, 2010. 8:34 AMstargazer96 says:
Now i have thankyou
Sep 12, 2010. 5:14 AMknex_mepalm says:
Daddy, it went in my eye.
Dec 12, 2009. 10:54 AMGoodhart says:
You then need rain.
I would suppose that "snow" would do just as well
Dec 12, 2009. 1:38 PMGoodhart says:
Sure,  even a rain barrel, catching melted snow might work (using the whole roof as a gathering area, but adding its own "particles" to the mix at the same time. )
Dec 13, 2009. 4:36 AMGoodhart says:
And,  I am thinking that, at this time of year, if it would snow during or shortly after one, I may be able to just gather some snow off the ground.  Since it appears it is going to be too cloudy to see it again this year.
May 1, 2010. 3:26 PMxilefakamot says:
I'd have thought that micrometeorites would make a good nucleation centre for ice - so surely there'd be more in snow?
May 2, 2010. 6:52 AMGoodhart says:
I suppose for the smaller ones......
Aug 30, 2009. 3:47 PMDELETED_DELETED_HIVLTGE1 says:
(removed by author or community request)
Dec 12, 2009. 10:51 AMGoodhart says:
I wonder why he deleted his comment or why it was deleted?
Dec 12, 2009. 1:34 PMGoodhart says:
Ok, well then, consider this a complimentary bump  ;-)
Jan 17, 2009. 6:44 PMkenny94 says:
May 6, 2009. 12:15 PMfodo says:
that's a metamorphic rock
May 2, 2009. 1:58 PMHunter4000695 says:
It looks like a Iron Meteorite or a Chondrite. But a meteorite of that size would have made a big crater. Etleast 40ft across and 20ft deep.
Jan 18, 2009. 7:32 AMkenny94 says:
i found it
Jan 18, 2009. 7:33 AMkenny94 says:
it is also really heavy for it's size
Jan 18, 2009. 9:19 AMkenny94 says:
a little bit, and from a real life perspective it does look melted, I have a bad camera...
Jan 18, 2009. 8:31 PMNachoMahma says:
. Most meteorites of that size that I've seen (admittedly not many) have been pocked/pitted. That looks like a piece of igneous (or maybe metamorphic) rock to me.
Feb 10, 2009. 7:29 PMSKYNET 2.0 says:
looks like a piece of jasper or obsidian.
Feb 12, 2009. 1:10 PMiPodGuy says:
Whoa. Fav'd.
1-40 of 129next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
831
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
