loading
Picture of Gladiator Trident
In this Instructables tutorial, we will show you how to make a gladiator trident.
Step 1: Materials
Picture of Materials
PVC(At least 5 feet long)
Foam Sheathing
Paint
Fish Net
Dremel
A cutter of some sort
Not Shown:
Cardboard
Exacto knife
Step 2: The Handle
Picture of The Handle
If you have a PVC pipe that is longer than 5 feet, cut it down and paint it. This will become the handle. You want to have many coats of paint so that the paint is completely smooth.
Step 3: Templates
Picture of Templates
Cut out the cardboard templates. There are four pieces:
A straight 11" for the middle prong
2 - 14" piece for the side prongs
12 - 2" diagonal pieces
2 - attaching pieces
Step 4: Cutting the foam
Picture of Cutting the foam
First, draw the pieces onto the foam. Using a Dremel to start the cut, cut the foam with an exacto knife. Use the Dremel on a low setting or you will lose control of it.
Step 5: Painting
Paint the pieces. Do not use spray paint as it will eat away at the foam.
Step 6: Final assembly
Glue the pieces of the head together. Then glue the head to the body. Make sure to wipe away any excess glue.
Dakota Joel9812 months ago
Nice, though I would have to have it in steel, not pvc and foam; great job though!
Dakota
same
poofrabbit3 years ago
Is that first picture your finished piece? If so, wow, that looks awesome, I never would have believed that you used foam. A suggestion on painting. If you use an acrylic based paint and seal the foam, you can then spray paint on top of it. :)
