3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Glass Block Christmas Decoration
I received one of these as a gift last year, and figured how hard would it be to make one. It was not as easy as I thought but just about anyone can make it with a little caution and safety measures.
Use a glass building block to make a decoration, by drilling a hole and inserting Christmas lights, then add some decorations on the outside of the block.
Step 1Prepare to drill the glass block.
Items you will need for this step include:
8 in X 8 in X 3 in glass block (Home Depot)
glass and tile drill bit 1/2 inch
Drill press preferably
Water
Gloves
and Eye protection
30 comments
Nov 18, 2010. 8:29 AMtwighahn says:
oneside with a bow the oher with and etching
etching powder and stencils
Aug 19, 2008. 6:24 PMaireamme says:
These blocks also come with predrilled holes, making the project easier. T here's also a prodcut called "Create A Block" that is basically the same thing in acrylic (http://www.artsandcraftsbyrayson.com/02.html). I work for a company that sells a great product to decorate these- check out my website: http://veronica.uppercaseliving.net . In particular, the "Embellishment Library" has some great items (go to Products, then Idea Catalog). In the Idea Catalog, the 6x6" items fit perfectly on 8x8" blocks, too!
Nov 18, 2010. 8:26 AMtwighahn says:
i wonder if those acryliuc blocks are fish safe
Dec 9, 2008. 1:24 PMDIYDragon says:
These would look way cool with etchings on them.. : ) I had some of these too, and didn't know what to do with them.. Blast my anti-pack rat-ness..
Nov 18, 2010. 8:25 AMtwighahn says:
etching powder
Nov 11, 2009. 5:31 PMZorik says:
For drilling, put one or two of the blocks in a bucket, they should fit tight, and fill the pail with water till 1/4 inch or so above the blocks. Then drill, coolant is always on the bit that way. When the hole goes through the pressure inside pulls in water, then shake and rinse out the glass dust. Submerging also keeps the fragments and dust on the outside from flying around while drilling.
Nov 18, 2010. 8:24 AMtwighahn says:
great idea for those of us using hand held drills
Nov 18, 2010. 8:23 AMtwighahn says:
if i used l.e.d.'s and solar power this would be prefect for my motorhome
May 16, 2010. 6:12 PMleannenmeeks says:
 another thing that could be done with this is to use the potpourri that comes in a bag when the lights are plugged in they heat up and it warms the potpourri up and it makes the whole house smell
Dec 26, 2009. 11:31 AMmrubesch says:
I made a batch of blocks for Christmas this year using both the angled drill bit as pictured and also the rigid brand circular one and found that the rigid brand cut a much cleaner hole and was definitely worth the few extra dollars
Dec 6, 2009. 7:13 AMbloomautomatic says:
Great job.  Hope I have time to make a few this year.
On the coolant, kerosene is the lubricant that the old timers used when cutting glass.  Never tried it with a drill.
As for etching, I've seen people use stencils and a sand blaster to etch glass with very good results.
Feb 21, 2009. 6:11 AMThePyroManiac says:
Suggestion - you can also try glass tiles. They're just a square of glass with spacers on all four sides used in designing. I think gluing two together might be easier than drilling a hole in a glass block.
Jan 30, 2009. 11:24 PMMiss World says:
I've always wanted to drill glass ... I should get that drill bit.. thank you so much for the instructable.
Dec 27, 2008. 9:26 PMlambsb says:
Very nice instructible. Makes a very pretty decoration and could be decorated for many occasions! Take a look at my instructible, the Mod Podge stained glass would work on these too!
Stained Glass Instructible
Nov 27, 2008. 5:50 AMIW5 Industries says:
something to do with those spare glass blocks! yay!
Nov 27, 2008. 5:48 AMIW5 Industries says:
i actualy like the dust inside of it it looks frosty....lol nice i'ble
Nov 26, 2008. 8:48 PMmickeymoose703 says:
Today, I found a glass block for crafts in Lowes for $9.95. It is predrilled with a 1-3/4" hole and a comes with a plastic plug slotted for the power cord exit. Good deal!
Nov 26, 2008. 3:02 PMwaverider894 says:
To clean it, could you pur water in and pour it back out? I might make this for my mom
Nov 12, 2008. 11:55 AMselena_1977 says:
I plan on making these for friends and decorating the blocks with stain glass window paints and stain glass patterns. The possibilities are near endless with this project.
Nov 12, 2008. 12:25 PMselena_1977 says:
also there is a glass paint that creates a frosted glass effect that helps diffuse the light and make it glow softer. Very pretty.
Dec 30, 2007. 8:10 PMdeancp1 says:
My wife is after me to make some of these for her. She says there are sources for plastic blocks - no worries for shattering when drilling. Also supposed to be lighter and not as dangerous to drop, both for the block and for your toes...
Dec 31, 2007. 4:41 PMdeancp1 says:
Cool, sounds like the warnings of block breakage are overstated. Thanks for the info.
Dec 31, 2007. 5:35 PMLinuxH4x0r says:
Great instructable! You could etch it by using acid, sandblasting or even just sanding
Dec 31, 2007. 2:17 PMcanida says:
That looks great! What a neat Christmas present.
Dec 30, 2007. 9:24 PMjrc976 says:
I made one of these for my x for christmas last year. I etched everything into it. It turned out amazing!
Dec 30, 2007. 5:02 PMGorillazMiko says:
Woah... nice job! That's amazing, I really want to do this. Maybe I will. :-) (favorited)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:hlong
