Glass Bottle Oil Lamp
 by Aira.vj
Make a small decorative oil lamp out of an empty glass bottle with screw-on metal lid. It's cheap, easy, and possibly romantic.
The lamp is filled with half water and half oil (or all oil if you like, but it's not as pretty!), and will burn for several hours depending on its size. The one I made will burn for a good twelve to fourteen hours, perhaps longer (I haven't exhausted it yet). All of the materials I used, I had lying around already.
There are endless variations that can be made. If you ever did the experiment in grade school with food-coloring-dyed liquids that float on each other due to different densities, you can turn this into a beautiful piece of artwork. Glycerine and rubbing alcohol work well. Cork will float between the water and oil.
Step 1: Materials
You will need the following materials:
1 glass or heavy plastic bottle with metal screw-on lid
1 sharp poking implement (I used the pointy end of a metal compass, but anything sharp, like a rusty old nail*, would work just as well)
1 bottle of olive oil
1 piece of 100% cotton scrap (I used a clean old sock with a big hole in it) **It's important that it be all cotton. If there is polyester or anything else in it, it may produce unhealthy fumes when it burns.
1 pair of scissors
*Rusty old nails are dangerous and should never be used for anything.
Step 2: Prepare The Lid
Remove the metal screw-on cap and get to work poking a hole in the center of it with your sharp poking implement. Be careful doing this, as it's possible for the implement to break through suddenly, and you don't want a pierce your hand by accident. In fact, you probably don't want to pierce your hand at all. So go slowly - a twisting motion works well, or, if you have a drill handy, you can just use that and save yourself time and energy.
Step 4: Combine Lid And Wick
This is the hardest part - you need to get the wick through that little hole. It helps to push the wick through, slowly, with the compass needle or the end of a bent paper clip. Once you get a little through, use your fingernails to gently pull it the rest of the way. If the hole feels really tight, you may want to widen it with the scissors - if it's too tight, it will stop the oil from climbing up the wick, and the lamp will not burn for very long. However, it needs to be tight enough that a slicked-up wick will not slide down through it by accident.
Once the wick is through, screw the cap onto the bottle. Pull the wick through the cap so that the very bottom of it is just above where you want the water/oil line to be. If you want to fill the entire bottle with oil, you can leave it as long as you want.
Step 5: Fill 'er Up
Now that you have measured out the wick, fill the bottle with water (and/or any other layers you want under the oil, decorated with food coloring, if you like), taking care not to fill it too much. Screw the cap with wick back on to make sure that the wick isn't getting wet before proceeding.
Next, fill the rest of the bottle up with oil. If you have a large bottle, the oil will be full of bubbles - wait for them to disappear. This may take a few minutes, so find something constructive to do in the meantime.
Once all the bubbles are gone, you can put the cap back on. Drop the wick slowly into the oil so that it has a chance to sink. Be sure to screw the cap on tightly - if it's on too loosely, and by some unhappy accident the bottle were to tip over, oil could go everywhere and could start a nasty fire.
Of course, it should never tip over. But it's better to be safe, right?
Step 6: Let Sit, Then Light
Now for the profoundly boring part: let it sit. I reccomend letting it sit for at least an hour, so that the entire wick is completely soaked with oil. If you don't wait long enough, and it's not completely soaked, the wick will burn off and the lamp will go out.
The wick should last you a good long time, but if you ever need to, you can pull more through the cap or easily replace it with more cotton scrap.
The lamp may take a few seconds to light, as oil doesn't light easily, but once it is lit it should stay that way until you either blow it out or run out of oil. It is easily blown out, and the light is bright enough to read by.
Never leave a lit oil lamp unattended. As I mentioned earlier, if it were to spill - maybe a cat or dog knocks it over - the results could be very, very bad. Even with the cap screwed on tightly, fires spread very easily and more quickly than you may realize. I take no responsibility for anyone who burns their house down with one of these things!
1-40 of 136Next »
SIRJAMES09 says: Mar 29, 2012. 2:12 PM
I have a Q.
OK, I made an oil lamp & used extra virgin olive oil straight out of the bottle(because that is what I had), I pulled the wick upto 1/4 inch, let the lamp sit over night, lit the lamp & it went out on its own...I pulled the wick upto 1/2 inch & the same thing happened. Both times its acting like it's not getting oil(sputtered before it went out).
What did I do wrong?
The jar I used, is about 2 - 3 oz. & the jar is 3/4 full of oil. The wick is longer than the jar is tall plus I tied a weight at the very end of the wick to make sure that it would sink into the oil, so I have about 3/4 of the wick down INTO the oil.
The thing the wick goes through, I bought on Amazon & it's (supposedly) made for oil lamps...I have tried to think of everything that I may have missed, but I'm drawing a blank. Did I mention that the wick is cotton?
Help!
Gregmink in reply to SIRJAMES09Apr 12, 2012. 9:57 AM
Just a thought - but if your tolorences were very tight between your lid and wick in an attempt to hold the wick in place and prevent it from falling into the lamp, then you may be creating a vacuum in your oil reservoir as the oil burns off, preventing the capillary action of the wick to take place. Once the flame burns out, the dry wick breaths enough to equalize the pressure in the reservoir, then the wick takes the oil and re-lights with no problem; until the vacuum is recreated. I would leave the top of the jar unscrewed and try to burn the lamp - if that fixes it, then find a way to vent the jar and you'll be good to go!
steam_cannon says: Jan 11, 2008. 7:46 PM
It's a fun project, but you really need to add one more step. The wicking needs to be soaked in salt and dried. Most people doing this project will run into the problem that their wick burns out in 10 - 20 minutes. To match and even out perform commercial wicking, just add salt. Salt prevents the cotton from charring too early so you can burn your lamp for an hour or two without any adjustments.
To salt the wicking:
1. Cut your wicking from cotton cloth.
2. Put your wicking in a bowl with a little water.
3. Pour table salt over the wicking.
4. Squeeze the wicking dry and then dry further on a tray. You can bake it dry in an oven at 200F for 20 minutes or just let it dry overnight. It will be crusty with salt but that's good and the wicking will still be reasonably flexible.
This is what I do making my lamps and candles...
http://www.instructables.com/id/Making-oil-lamps-and-candles-for-free/
SIRJAMES09 in reply to steam_cannonFeb 16, 2012. 4:13 PM
Then AFTER you salt the wick, do you just use it however you normally would? or is there something else you do before using the wick??
I ask, because I have never ever heard of salting a wick...
steam_cannon in reply to SIRJAMES09Mar 8, 2012. 9:25 AM
After you salt the wick you let it dry out, then use it like any other wicking.
You may not have heard of salting wicks before, but companies seem to do this. I noticed that after some candles get wet, the wicks don't work as well even after the wick had dried have dried. This lead me to looking up wick additives and I found a reference in an old book about salt being used as an additive. I tried that and it helps.
Aira.vj (author) in reply to steam_cannonFeb 1, 2008. 6:11 AM
Thanks for the tip on salting! I didn't know that, and I have been having trouble with my wick dying too quickly.
agis68 says: Dec 10, 2008. 6:53 AM
Nice idea BUT!: The combination of that kind of bottle with the huge quantity of olive oil SCARES me. Some years ago I made something like that but more stable. A jar (from marmelad) is more suitable take a look
SIRJAMES09 in reply to agis68Feb 16, 2012. 4:09 PM
I LOVE THAT!!! that is an awesome looking lamp!!!
how did you attach the lamp parts to the jar lid???
is it bright enough to read by?? what kind of fuel do you use?
that is just too cool!!!!! :P
agis68 in reply to SIRJAMES09Feb 17, 2012. 9:27 PM
I am really happy you like it. We spend enough days in my cosi country house next to the lake here in Greece. But we had to pay a lot of money to connect the house with the electricity...so i said to my wife...why to spend and waste money lets make it like some years ago...So we cook and heat by woods,or gas and we read having ths . One of this lasts for 2 weeks using it every night. The upper part is from original lamp but little smaller.. Now to attach this on the jar i take an old case made of copper .Ideal for this are the lamp sockets. So I made a big hall and i pass the soket now the base of the lamb can be supported from the socket so that's is very easily and effective....I used to make dozen of thems and sell them in the local village bazar for 5 euro....
hope hlping you...
amethysteria says: Jan 4, 2008. 1:35 AM
Yay! I've made one, although I do have to admit that I tried it outside first, just in case it exploded! Aargh, I watch too much tv!
SIRJAMES09 in reply to amethysteriaFeb 16, 2012. 4:17 PM
oil can not explode like a bomb....it is too thick, too coarse, & it burns too slow. an explosion of ANY kind needs to be an extremely fast burn.
that is why cars & lawn mowers do not run on oil.
amethysteria in reply to SIRJAMES09Feb 17, 2012. 3:30 PM
Good to know! Unfortunately, I have to admit that i'm one of THOSE women who dont know that.
leevonk says: Jan 23, 2007. 6:16 PM
I did this to burn the insulation off of electrodes in my lab. I used some 78% alcohol we had and the thick string from a mop head I bought from the dollar store. It worked well, but the alcohol evaporates if you don't cover up the lamp head really well when not in use (alcohol gets soaked up into the sting, evaps, repeat).
SIRJAMES09 in reply to leevonkFeb 16, 2012. 4:30 PM
a mop head from the dollar store??
I never thought of that....LOL
simple. cheap. effective. I like that idea!!! TY for sharing. :)
SIRJAMES09 says: Feb 16, 2012. 4:27 PM
Somewhere in this Instructable, Sappho made a comment about slowly lowering the wick into the oil so that it would sink into the oil....
I have an idea that just might be faster & maybe easiier to lower the wick into the oil.
tie a weight on the bottom of the wick. the weight cold be a nut from a bolt; or the bolt itself; a washer,anything that weighs more than the wick should work....
and if the weight should come undone & fall to the bottom of the bottle, oh well. you still have the wick in the oil which is what you needed to get done in the first place....
just a thought.
SIRJAMES09 says: Feb 16, 2012. 4:01 PM
I have a Q:
what about natural Jute Twine as a wick? would that work or would it just go out/stink up the house?
I do a lot of gardening & I use Jute to tie up the plants...I'm out right now but will be ordering more for the garden, that is why I asked....
cortwein says: Oct 21, 2011. 1:28 PM
Could you fill the whole bottle up with oil or do you have to have the water?
zoobr says: Sep 26, 2011. 4:55 AM
if i weave my own wicks, will it matter how tight i weave it, eg if its a tight weave will it slow down the rate witch the oil is soaked up or wont it matter ?
TraumaComet says: Jan 17, 2009. 7:41 PM
Great Instro! This is green in so many ways that it boggles the mind. Cool.
burpreynolds in reply to TraumaCometMar 7, 2010. 8:23 PM
Could be greener if we were using oil that had to be thrown away anyway.  Like used fry oil, or even used motor oil.  Why waste?
ilpug in reply to burpreynoldsMar 15, 2011. 10:28 AM
motor oil is stinky and not nescessarily "green" it would work though, as long as it wasnt that modern chemical kind.
MEMJIM says: Feb 9, 2011. 3:59 AM
Great info Sappho, Thanks a Bunch. oh yeah, relative to Hycros' question, did ya' flick your Bic on the first date?
Hycro says: Jan 1, 2011. 9:44 AM
Did you place confidence in a personal relationship like the cap says?
maullove says: Dec 22, 2010. 10:33 AM
Nice, and I love the Jones soda bottles!
Berserker242 says: May 18, 2010. 6:23 PM
What all kinds of things can you burn in one of these or similar DIY jam jar lamps?
Can you burn tiki oil in them or is that too dangerous?
PMZ
biofueljunke in reply to Berserker242Aug 27, 2010. 12:23 PM
try veg and you will never go back
ecahseb14 says: Nov 29, 2009. 6:06 PM
does it matter if i use extra virgin olive oil?
biofueljunke in reply to ecahseb14Aug 27, 2010. 12:22 PM
try used oil from a local place i reccomend italian food the oil stays clean and iv also heard japanese food dosent mess up the oil too bad just ask and you will have som free fuel
wilderness in reply to ecahseb14Aug 6, 2010. 1:02 AM
Extra virgin olive oil should burfine - but it seems like a bit of a waste. You can get lamp oil, or pomace oil - they're cheaper, and that way you're not wasting something precious.
Deathcapt says: Feb 5, 2009. 7:14 AM
If you filled it with alcohol as a fuel, it could double as an emergency molotov!
ret1614 in reply to DeathcaptJun 13, 2010. 7:21 PM
Ever tried an alcohol based molotov? They tend to not work very well. lol, and throwing this tiny little flame would cause it to blow out. This is much better as a candle. Oh, and alcohol burns with a blue flame, so no light, and vapour burns far better than liquid, so the wick wouldn't be doing it any favours. Leave the alcohol to the stoves
grue in reply to DeathcaptJul 19, 2009. 6:26 PM
alcohol is lighter than water, so it's always a molotov
wazzup105 says: Mar 25, 2008. 12:40 AM
Thank you for the suggestion to use an old sock for a wick. I've got some leftover oil (from the sundried tomatoes) which I am not using and throwing it away seems like such a waste. This is a nice idea to get rid of that old oil in a purdy manner this summer.
elyador in reply to wazzup105May 1, 2010. 3:17 PM
hmm, that oil might stunk when you burn it.
The best use for oil from sundried tomato jars is cooking. Cut up some italian sausages and fry them in it.
wazzup105 in reply to elyadorMay 1, 2010. 11:16 PM
I burned it outside, so it didn't bother me, but just use it for cooking... hmmm... I'll try that. Thanks. Anything but just throwing it away.
(actually I wasn't happy with the way it burned either)
Franch1z3e says: Feb 14, 2010. 4:41 PM
hey..i was just wondering if you could stagger the levels of oil and water and still have the wick go through all levels? or will this affect the wick, like will only the first level of oil burn and the rest be only for looks?
soundmotor says: Jan 22, 2010. 8:48 AM
Nice instructable. The only downside to a bottle is that if bumped, it could fall over. I'd like to try this with a wide-base jar or similar.
tigerboy says: Nov 18, 2009. 8:40 PM
To fill you in on the history of olive oil lamps. They were used with olive oil in them on ships so that if they spilled they wouldn't light the ship on fire.
allstarn07 says: Jun 26, 2008. 7:19 PM
I personaly wouldnt make this because its to easy to knock over and shatter the bottle and start a fire. Good idea though.
spitrat in reply to allstarn07Oct 16, 2009. 8:53 AM
 I've seen this same technique used but the bottle was half filled with pea gravel, sand, pebbles ,or whatever, it stabilizes the base and you don't have to use as much oil.
1-40 of 136Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
