The lamp is filled with half water and half oil (or all oil if you like, but it's not as pretty!), and will burn for several hours depending on its size. The one I made will burn for a good twelve to fourteen hours, perhaps longer (I haven't exhausted it yet). All of the materials I used, I had lying around already.
There are endless variations that can be made. If you ever did the experiment in grade school with food-coloring-dyed liquids that float on each other due to different densities, you can turn this into a beautiful piece of artwork. Glycerine and rubbing alcohol work well. Cork will float between the water and oil.
Remove these ads by
Signing UpStep 1Materials
1 glass or heavy plastic bottle with metal screw-on lid
1 sharp poking implement (I used the pointy end of a metal compass, but anything sharp, like a rusty old nail*, would work just as well)
1 bottle of olive oil
1 piece of 100% cotton scrap (I used a clean old sock with a big hole in it) **It's important that it be all cotton. If there is polyester or anything else in it, it may produce unhealthy fumes when it burns.
1 pair of scissors
*Rusty old nails are dangerous and should never be used for anything.
OK, I made an oil lamp & used extra virgin olive oil straight out of the bottle(because that is what I had), I pulled the wick upto 1/4 inch, let the lamp sit over night, lit the lamp & it went out on its own...I pulled the wick upto 1/2 inch & the same thing happened. Both times its acting like it's not getting oil(sputtered before it went out).
What did I do wrong?
The jar I used, is about 2 - 3 oz. & the jar is 3/4 full of oil. The wick is longer than the jar is tall plus I tied a weight at the very end of the wick to make sure that it would sink into the oil, so I have about 3/4 of the wick down INTO the oil.
The thing the wick goes through, I bought on Amazon & it's (supposedly) made for oil lamps...I have tried to think of everything that I may have missed, but I'm drawing a blank. Did I mention that the wick is cotton?
Help!
To salt the wicking:
1. Cut your wicking from cotton cloth.
2. Put your wicking in a bowl with a little water.
3. Pour table salt over the wicking.
4. Squeeze the wicking dry and then dry further on a tray. You can bake it dry in an oven at 200F for 20 minutes or just let it dry overnight. It will be crusty with salt but that's good and the wicking will still be reasonably flexible.
This is what I do making my lamps and candles...
http://www.instructables.com/id/Making-oil-lamps-and-candles-for-free/
I ask, because I have never ever heard of salting a wick...
You may not have heard of salting wicks before, but companies seem to do this. I noticed that after some candles get wet, the wicks don't work as well even after the wick had dried have dried. This lead me to looking up wick additives and I found a reference in an old book about salt being used as an additive. I tried that and it helps.
how did you attach the lamp parts to the jar lid???
is it bright enough to read by?? what kind of fuel do you use?
that is just too cool!!!!! :P
hope hlping you...
that is why cars & lawn mowers do not run on oil.
I never thought of that....LOL
simple. cheap. effective. I like that idea!!! TY for sharing. :)
I have an idea that just might be faster & maybe easiier to lower the wick into the oil.
tie a weight on the bottom of the wick. the weight cold be a nut from a bolt; or the bolt itself; a washer,anything that weighs more than the wick should work....
and if the weight should come undone & fall to the bottom of the bottle, oh well. you still have the wick in the oil which is what you needed to get done in the first place....
just a thought.
what about natural Jute Twine as a wick? would that work or would it just go out/stink up the house?
I do a lot of gardening & I use Jute to tie up the plants...I'm out right now but will be ordering more for the garden, that is why I asked....
Can you burn tiki oil in them or is that too dangerous?
PMZ
The best use for oil from sundried tomato jars is cooking. Cut up some italian sausages and fry them in it.
(actually I wasn't happy with the way it burned either)
