3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Glass Bottle Oil Lamp
Step 4Combine Lid And Wick
This is the hardest part - you need to get the wick through that little hole. It helps to push the wick through, slowly, with the compass needle or the end of a bent paper clip. Once you get a little through, use your fingernails to gently pull it the rest of the way. If the hole feels really tight, you may want to widen it with the scissors - if it's too tight, it will stop the oil from climbing up the wick, and the lamp will not burn for very long. However, it needs to be tight enough that a slicked-up wick will not slide down through it by accident.
Once the wick is through, screw the cap onto the bottle. Pull the wick through the cap so that the very bottom of it is just above where you want the water/oil line to be. If you want to fill the entire bottle with oil, you can leave it as long as you want.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Sappho(Daily Underground Comic)
