     The cube glass decoration are beautiful to look at. The cost of a 3 Dimensional Picture Cube has gone down and can now be seen in generals stores and even dollar stores. But the light stand is still expensive. This Instructable will show you how to build one for your own picture cubes for $10. I used" AutoDesk Inventor Fusion" to design the glass stand before I actually built it. you can find this drawing at 123D gallery.
Please vote, there are no local object printing services in my area. I have not heard of any trusted online sources so my projects have been build with cardboard and/or clay.
Step 1: The Box
     The measurements of the stand are in the images below.
     Supplies:        Tools:
          Flashing Light Kit (Radio Shack)                                                  Solder Iron
          Different Color LED's (Optional)                                                   Solder Wire
          Hard Cardboard        Masking Tape
          Aluminum Foil        Hot Glue Gun
          2 Bottle Caps        Ruler
          Speaker Word        Drill
          Paint        Drill Bits
          9 Volt Battery        Razor
     Cut the Hard Cardboard and tape together and create boxes using masking tape.  Cut 2 holes into the top box 7/8 inch in diameter. Paint the top box. Do not paint the bottom box because it will cause the two boxes to stick to each other.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
